DistroAV - Network Audio/Video in OBS-Studio using NDI® technology
DistroAV - Network Audio/Video in OBS-Studio using NDI® technology 6.2.2
To set the "receive" group, this is generally done via NDI Access Manager (NDI Tools), this is not something that (IMHO) should be set in the receive as the NDI Source you either have access or not.
The only "option" I could see is to "filter" source per group, if this is really a need, please log a feature suggestion with argument to have it prioritised.
More read on the groups : https://docs.ndi.video/all/getting-started/white-paper/discovery-and-registration/ndi-groups
Does the new version (after the major code change) no longer support transparency?
I'm sending lower thirds from a commercial app, that used to "just work" with a full-screen NDI source in OBS. The commercial app sends full color and a fade to transparent as you go up from the bottom, which OBS used to handle perfectly as a fade to camera, using the old NDI plugin.
Now, with no change at all to the commercial sending end, I get opaque black across the entire frame, which I can key out, but it also wrecks the effect that used to be there.
Not supposed to have changed.
Please file a Support Request at : https://github.com/DistroAV/DistroAV/issues/new?template=3_support.yml
If you came from a pretty old version, you are likely looking at both OBS changes & DistroAV changes.
DistroAV updated DistroAV - Network Audio/Video in OBS-Studio using NDI® technology with a new update entry:
New Version : 6.1.1
Changelog of 6.1.1 (and 6.1.0)
This version requires OBS 31 and NDI 6. It is enforced and the plugin will not load if not meeting this requirements. More detail
Fastest Way to get it​
Windows via Winget
winget install --exact --id DistroAV.DistroAV
MacOS via Homebrew
brew install --cask distroav
What's Changed​
6.1.1
  • Restore OBS preferences dialog on...
Turns out it was the Latency setting. Only "Default" supports transparency and, wanting a near-instant response, I had it on the lowest (unbuffered) one. "Default" isn't too bad though, so I left it there and now I have transparency.
There's already a support ticket / bug report for that, wanting transparency support on *all* settings, which prompted me to try that.
Correct, "lowest unbuffered" does not have alpha. The project is looking to improve the Alpha layer support, no guarantee that this could be done for the "lowest settings".
can i have a download link for the NDI plugin compatible with OBS 29.0.1 running on a MAC OS 10.15.7
Thanks
This is tricky for such an old version
OBS 30 is a requirement for DistroAV to work since... Nov 14, 2023.
OBS 31 is a requirement since June 2, 2025.
Any older version are not supported and a LOT of bugs have been fixed since then.
Oh, and the required "NDI SDK" is likely not to work / be available either.
Question about HDR transmission: My GamePC has Screencapture HX running and is set to HDR, both in Windows 11 and in the game, either native or via RTX-HDR depending on what the game can do. If I now transfer this image content via NDI 6 to the streaming PC, which is running in SDR, I get an extremely washed-out image in the NDI source. I have set the screen capture HX to HEVC (10-bit). In the DistroAV settings, I could see that only the two colour spaces BT601 and BT709 are offered, but not BT2020.
Are there plans to add this in the future?
Hey everyone,
I’m really hoping someone here can help me out or at least point me in the right direction. All I’m trying to do is stream gameplay from my Nintendo Switch, but I’m running into some frustrating issues and I feel like I’m missing something really basic.
Here’s where I’m at:
I’ve installed NDI Tools, and after some trial and error, I’ve finally gotten OBS to recognize both “NDI Source” and “DistroAV NDI Settings” as available sources — these weren’t showing up at all initially, so that felt like progress.
However, now when I try to add those sources to a scene in OBS, all I get is a black screen. No video, no signal, nothing — just black. I’ve tried restarting OBS and my Mac, rechecking all the cables and inputs, and making sure the Switch is powered on and connected. Still no luck.
Here are my current specs:
  • OBS version: 31.0.4
  • Computer: MacBook Pro with Apple M1 Pro chip
  • Capture device: Elgato Game Capture HD60 S
  • Console: Nintendo Switch
The Elgato device itself seems like it should be working, but I’m not seeing any actual video feed coming through OBS. I know the HD60 S can be tricky with macOS, so maybe there’s a compatibility step I missed? Or maybe I need additional drivers or middleware beyond NDI Tools?
At this point I’ve been down a dozen rabbit holes with no clear answer, and I’d really appreciate any help — whether it’s confirming I’m doing things right or pointing out something obvious I may have overlooked. I'm trying to keep things as plug-and-play as possible, but it's not going smoothly.
Thanks in advance to anyone who takes the time to respond!
My common response, when troubleshooting audio and video sources is to test completely OUTSIDE of OBS Studio,( ie OBS Studio not just in background, I mean OBS Studio NOT running at all *due to potential of 'locking' some sources by design). Basically, you add a LOT of complexity by trying to get a source into OBS Studio if you aren't 100% sure (technically, not via assumption) the source is working at Operating System level as needed
With NDI Tools, you should be able to view incoming NDI video - can you? have you set Operating System (OS) permissions correctly? Are OS network firewall settings adjusted to allow the incoming NDI traffic?
We bought the MSI Raider 18 HX AI A2XWJG-416US 18" (https://www.microcenter.com/product...jg-416us-18-gaming-laptop-computer-core-black)
For the Church streaming and I have it all setup with the latest version of OBS 31.0.4 and the latest distroav-6.1.1 and I'm using 5 - FoMaKo NDI PTZ Camera,30X Optical Zoom, AI Auto-Tracking
And only issue I'm seeing with the new laptop is OBS seems to have a memory leak and when it climbs up to 2gig on the memory leak the OBS app crashes. And when it crashes I can't even close OBS without doing end task in task manager
Have you even seen obs have memory leaks before and what possible fix?
Or could it be the Laptop is too powerful for OBS ? It has a mobile 5090 with 24gig and 64gig ram and intel 9 285HX
I tried going into OBS safe mode but the NDI devices don't show in safe mode. So I rebooted and went into normal mode and the something happens. On taskmgr OBS climbs memory until it crashes. I wonder has OBS programmers tested OBS with a laptop nivida 5090. Attached some logs. Has anyone else seem this issue?
So Could this be the new Distroav 6.1.1 or the NDI 6 runtime software?
That's funny... no such thing as too powerful
That said, gaming laptops tend to NOT have the same heat dissipation design (capability) of a true workstation laptop. And that rig more than capable, if properly configured (lots of default Operating System settings NOT designed for sustained performance)
So, can't comment on memory leak (if OBS Studio or 3rd party plugin)... and you are NOT on latest OBS Studio (though I almost always wait and let dust settle a bit before jumping to latest release ... see FB streaming oops with 31.1.0 hence prompt 31.1.1 release)
What I do suggest is learning how to monitor thermals on that laptop, and especially be able to identify if/when thermal throttling starts to take place (be that CPU, GPU, RAM, NVMe, etc).
Curious if anybody has seen this issues with the latest version: "Main Output" tick box will stay persistent between closing and opening OBS sessions. However, after a reboot, the tick box is always unchecked.
What are the best stable settings with minimal audio lag that you all have found? I've been struggling the past month or so with the audio skipping or cutting out on occasion since the latest OBS update
It's a long list, but short story is, if you set your Audio to "Unbuffered" (under AV), it should work (although you still get the occasional 1 second audio cuts and any new Stream will have static for a few seconds at the start) while losing slight game/network performance.
Also make sure to restart your OBS between games.
Long story: Every since AFTER OBS 27 (and that period of time with a specific revision of NDI + Windows + Nvidia updates related to WDDM), anything that "spikes" your PC usage from a "low state to maximum state" (mostly on weaker PC's I think) will start lagging the audio.
Please note nVidia is especially notorious for their Audio DPC Latency issues ever since the 1000GTX Series, and no one has tried to find a proper workaround (other than making your CPU and GPU no idle and always work at 25% power levels or P1/0 State).
For example (depending on Hardware and Drivers): Start OBS > Start Game = Audio Lag. HOWEVER, if you Start Game > Start OBS = No audio lag UNLESS the game does some fancy loading where they switch power states on you hardware (ei; old games like Deus Ex 2).
If game is hitting upper limits of your Hardware while doing extra work (ei; UE5 Game caching Shaders), you get Complete Audio Dsync at best, 3-9 seconds of cut audio at worst.
If Game has multiple options for Audio, try and switch them around before you start streaming or recording, since changing them Mid OBS usage will sometimes completely break the audio and requires restarting both OBS and the Game.
Some people reported setting Audios channels (both OBS and PC, as well Mic) to 44Khz instead of 48 Khz improved the Audio Lag issues (I personally saw no difference and it's placebo at best).
People with more expensive GPU (which have 2 Encoders) reported not having these issues compared to Mono-Encoder cards (like the x60 Series on nVidia).
Some people reported disabling the Intel Microcode related to Meltdown improved the issues (it improved performace for me, but not the Audio issues).
Some people reported Software for Mice and Keyboards (ei; ICUE) can be another source of issue. I can confirm that, but they're usually an issue for your entire PC and not only OBS (especially ASUS Crate).
Don't ask my collectively everyone decided to break stuff right around 2022.
Really odd. For some reason today I get random stutters every few seconds on the 2nd PC and I never did prior to that. I uninstalled both the NDI and DistroAV apps, and then manually made extra sure to delete their folders, then reinstalled. This is on Windows 11 for both machines.
Main specs:
-Gaming
5900x
32 gigs
RTX 3080
-Streaming
5700x
32 gigs
RTX 3060
GE800 is the router, which has all 2.5 and 10 gig ports. Running a fairly new firmware 1.2.1. I tried resetting the network settings in Windows, tried Framesync, etc.
I've been using this for years and only now is this happening. I wonder if it is some Windows update or some bug with the router's firmware, etc. I don't get it. I've tried re-adding the source after deleting it, etc. It will be smooth and then chug like it's dropping frames even though OBS does not report any dropped frames.
2nd PC settings - CBR/6000, 2 sec, fast, high, none
If I use a single pc to stream it's smooth as butter but I want to continue using the 2 pc setup I've had for years.
I wonder if it is a setting in the router? I have Flow Control turned off on the NICs, the router for WAN and LAN. I do not limit game capture fps.
? can anyone assist
Ran perfectly (besides minor audio blips) yesterday now I have the same issues as Jaybonaut. Did some windows/gpu driver updates and rolling back gpu driver updates did not fix the issue. (Using DDU, although not in safe mode)
Choosing "Lowest" for "Bandwidth" makes the source less of a slideshow but that's not what I'm looking to use. It's also still not the full 48fps I'm looking for. Tried restarting router multiple times and ran a bandwidth test for it, looks like very stable half gigabit per second.
edit: added info
~Half gigabit for reading, ~.9 gigabit for writing.
edit: Actually the "Lowest" bitrate setting does produce stable 48fps after double checking, was just the preview that looked off.
edit: Audio also looks stuttering from the preview with "highest" bitrate on the video btw. Changing framesync on/off, sync mode does nothing to alleviate the problem as well.
