DistroAV - Network Audio/Video in OBS-Studio using NDI® technology
DistroAV - Network Audio/Video in OBS-Studio using NDI® technology 6.2.0
distroav-6.2.1 linux requires libqt6gui6t64 and libqt6widgets6t64 but Kubuntu 26.04LTS changed there names thay removed the "t64" in the name, now the distroav.deb will not install corectly and complaines of missing dependincys.
For something like that, I imagine that either Ubuntu in general (across all of its flavors) or perhaps even Debian that Ubuntu itself is based on, did that, and everything else simply inherits it. So not just Kubuntu, but potentially a much wider problem.
For what it's worth, Ubuntu Studio 26.04 LTS has this plugin available to install natively, according to its Release Notes under New Packages:
Not sure if it was an odd courtesy, or a direct solution to this exact problem by building it themselves and offering the binary, but it might be a solution. UStudio uses KDE too, so you're not losing that by switching to it from Kubuntu. Or you might just add UStudio's repository and install it from there.
i managed to get it working in a way with "sudo apt install obs-studio distroav" to get a non snap&flatpak native version.
i ended up with obs v32.1.0, sadly this means a few of the plugins i use that i have saved dont work with it.
how ever i am sorting it out little by little some work some dont, i may just have to use older versions of plugins an hope it works or just wait till updates come avalible
i was orignaly on linux mint and was liking it but i found a new way to capture things [games & vtube programes] but it requierd pipewire v1.2.7 minumum mint had v1.0.5.
i tryed adding a newer pipewire ppa but when mint updated then next day the ppa updated it broke all my audio and trying to fix it as a linux novice as expected i made it worse and mints DE wouldnt even load, managed to recover the DE so i could backup my files or clone the drive to an external.
so after that feasco i checked several distros an since i do vr and vtubing i want steam updates as soon as valve releases them so thet ment i needed a debian based distro and i considered studio but its pipewire wasnt as new as kubuntu plus i seen posts about that kubuntu is way less pushy about forcing snaps. XD so here i am since i had to be so picky [head smash wall]
kubuntu 26.04 LTS has pipewire v1.6.2
Yeah, I've never been impressed with the concept of containers, for something like OBS. They're great for wide compatibility and security, because they're self-contained with all the required dependencies and they're not allowed outside of their separate containers by default. But that's where the benefits end. For a performance thing like OBS, that needs access to hardware (GPU) and continuously churns through a lot of data (live video), containers don't really work all that well.
Yes, you can open up the permissions, until you've completely nerfed the security part to make it run, but you still have a performance hit and an awkward way to install plugins. If you move them from the container install directory to the native install directory (yes, they're different), they *might* "just work", but you have to do that manually and know where both of those directories are, which I don't because I gave up on non-native OBS a long time ago.
So for OBS at least, stick with native. Other things aren't worth fussing about - if Mozilla wants to snap itself, fine, let 'em do that - but OBS is.
Ubuntu Studio has a TON of stuff pre-installed and already working. If you're relatively new to Linux and don't want to mess with installing stuff yet, you might like that.
I would stick with the LTS versions of course, and wait for at least the first point release before grabbing the new one. 24.04 is supported for a full year after 26.04.0 is released, and 26.04.1 will come only a few months after .0. At the very least, .1 will include a lot of bug fixes that weren't caught during the pre-release testing, so you don't have to deal with those either.
In short, if you need something ***NOW!!!***, go with the latest 24.04.x. Once 26.04.1 is out, *then* start to consider that version.
Hello DistroAV, I've Experiencing when I switch to other scene, my NDI Filter on one Scene is freezed. I hope you can fix that sooner. Thanks!
When OBS stops receiving data for a source, that source freezes on the last good frame. It does that for *all* sources, not just this one. Might that be what's happening?
Also, when a scene is not used anywhere, I think OBS stops rendering it. It keeps a hold on the source devices, so something else doesn't grab an exclusive lock on them in the meantime, but I think the internal scenes stop running when nothing needs them. So maybe there's a false negative about your scene being needed?
If that's the case, then you should be able to fix it by using that scene somewhere that doesn't really matter, but OBS detects as "needed". Maybe a projector, or the virtual camera, or use it in another scene that completely covers it, etc.
Would that be a change in more recent versions? on older versions, I recall discussion (not necessarily authoritative), that all Scenes in Scene Collection are rendered, so that you can switch scenes and have everything immediately available.
Now, is there a nuance of processing ALL of the inputs, but not rendering, sure. But previously, all Sources were locked while Scene Collection, not just a given Scene within a Collection, active. or at least that was my understanding.
That may have changed over the years and I not noticed?
OBS keeps a lock on all of its external sources, probably so another app doesn't steal one while it's not being used. If that were to happen, then OBS wouldn't be able to use it when you switch back to that scene. Not a problem on operating systems are aren't exclusive, but last I checked, Windows *still* is, so it's still necessary to be a dog in the manger for all sources. (at least as far as the OS sees, which is enough to keep the camera-active light on, etc.)
But, I don't think OBS processes what it gets from those sources, unless the result actually goes somewhere. I could be wrong, but I do seem to remember something to that effect. If filters don't count towards that detection, then that could cause John's problem.
Makes me wonder briefly about one of my rigs, that has a Source Record filter on one of my scenes that is never meant to make it to the Main Output. It always works; I always get a recording when I activate that filter. But I also have that scene projected to a TV, so that probably satisfies the detection and keeps the scene active, which allows the filter to keep working.
Subject: Bizarre NDI Audio Crackling Issue & Workaround (Monitor Output is Clean, Direct Stream is Distorted)
Something completely absurd is happening! I’m using the NDI plugin for OBS Studio along with the official NDI app on an iPhone 16e. The video quality is perfect, but the audio is a complete nightmare—heavy crackling everywhere.
BUT HERE'S THE WEIRD PART:
When I monitor the NDI audio source in OBS, the audio playing through my headphones/monitoring output is completely clean with zero crackling! So while the direct source output is unlistenable on the live stream, its monitored output sounds perfect.
I ended up trying an absurd workaround:
  1. I applied the Audio Monitor filter/plugin to the NDI source.
  2. I routed that monitored audio into a separate audio input device (I routed it through one of my display monitor's audio inputs).
  3. I added that input back into OBS as a fresh audio capture source for the stream.
...And the stream audio is now 100% perfect!
How is it technically possible that audio monitored and redirected from the original source into another via a "ghost" audio device works flawlessly on stream, while the original NDI source itself crackles and breaks when routed directly to the stream output?
Is there any way when the connection completely dies on the stream pc to restart the NDI part? I changed the nic settings for realtek cards and it works completely fine but atfer 4h the streaming pc would not receive anything at all.
Could not select anything in the dropdown menu. I had to forcekill OBS so it wouldnt create a new stream and then it worked again without any issues at all.
So if there is any way to just restart the service tell me or any other way to mitigate that. I'll be getting an intel nic too soon so that should be another headache gone.
