Question / Help Desktop audio randomly cuts out but microphone audio is fine
30phil1
Hello everyone,
I'm on OBS Studio with the OBS.live plugin. Since the beginning, I've been having a weird issue where the desktop audio completely cuts out for a second or two then returns like nothing ever happened. My mic is heard through the stream just fine but, even when OBS is open but not streaming, I still have this happen. All of my audio devices are set to the same 48 kHz sample rate which didn't change anything.
Log File
So far no one has replied but I'm assuming it had something to do with either a) the fact that I was projecting my display to a second monitor through WIFI or b) my PC not having enough resources to run OBS at the same time as my games. Still figuring that out however, I have seen less glitching when the preview is disabled.
Currently, I've begun using an actual second monitor plugged into my GPU like normal and I'll see if I can't fix up some settings with OBS (such as using Game Capture instead of Display Capture).
