Crash with Kernelbase.dll problem
CallMe233
I update to 27.2.3. The crash problem occurs when I try to open the software. I tried some old versions and they still didn't work.
This is the log for 27.2.2(32-bit) and 27.2.0(64-bit).
Any help from anyone is greatly appreciated.
Unhandled exception: e06d7363
Date/Time: 2022-03-10, 19:10:27
Fault address: 761FB922 (c:\windows\system32\kernelbase.dll)
libobs version: 27.2.2 (32-bit)
Windows version: 10.0 build 19044 (release: 2009; revision: 1566; 64-bit)
CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
Date/Time: 2022-03-10, 18:56:36
Fault address: 7FFDB8A44F69 (c:\windows\system32\kernelbase.dll)
libobs version: 27.2.0 (64-bit)
1. update all drivers from the manufacture homepage
2. Update Bios
3. check you ram with memtest
4. Check you windows files
Start CMD as Admin
type in
dism /Online /Cleanup-Image /ScanHealth
when finished
sfc /scannow
This specific crash is caused by your intel igpu drivers being out of date.
You need to update your Intel video driver. You have 2 ways you can do this:
  1. Update using the Intel Driver & Support Assistant, available at this link: https://www.intel.com/content/www/us/en/support/detect.html
  2. Update by selecting the appropriate driver for your OS and GPU, at this link: https://downloadcenter.intel.com/product/80939/Graphics-Drivers
Always reboot your PC once your drivers are updated, even if you are not prompted to.
