Question / Help AverMedia Live Gamer HD will only stream at 30fps no matter what...help!
8LAZ3
Hey guys, I just got the capture card 3 days ago and as the title says it; no matter what I change, how I tweak the settings, it just won't stream at 60fps! HOWEVER, with Recentral, I tried and it does stream at a smooth fluid 60fps but only for a couple minutes, after that my stream will go black and keeps on loading.
I stream in 720p@60fps
Using OBS only(no capture card), everything is OK, 60fps with the drop of frames here and there but that doesn't bug me.
When I use the Avermedia as the capture source though, it only captures/streams at 30fps.
If I open twitch video playback stats, it will obviously say 60fps because I set the fps to 60 in OBS and this is what OBS encodes and sends out but the capture card is actually capturing only 30fps or even less but I know it's NOT 60fps!
Here are my specs:
  • Motherboard: Asus M5A99FX PRO R2.0
  • CPU: AMD FX-8350 8 Core at 4.0Ghz
  • CPU Cooler: Cooler Master Seidon 240M Liquid CPU Cooler
  • RAM: 16GB(2X8GB Corsair Vengeance DDR3)
  • Graphic Card: EVGA GeForce GTX 760 Superclocked 2GB GDDR5
My OBS settings are as followed:
Encoder: x264 with CBR and padding
Max bitrate (kb/s): 3500
Custom Buffer size checked: 3500
Audio Codec: AAC
Bitrate: 128
Format: 48khz
Base Resolution: 1920 x 1080
Downscaled to 720p
Filter Bilinear (fastest)
FPS: 60
Advanced
Use Multithreaded Optimizations checked
Process Priority Class: Normal
Scene Buffering Time (milliseconds): 700
x264 preset: Faster
Encoding Profile: high
Use CFR checked
As for the Avermedia HD Capture C985 in OBS, these are the settings
Custom resolution checked: 1280x720
FPS: 60.0002 (tried changing it to 60 but always adds the .0002)
Everything else is default.
I'm fairly new to OBS so I don't know how to get a log file, help again please?
Thanks guys.
