AgentGolem50
So, I have a weird situation. I was trying to stream a recording for a school related thing. Because of the fact its an enterprise wifi and there would be a ton of movement so not a great way to work with wires I used a small portable router hard-wired into a laptop to connect to cameras over a dedicated wifi network for just the one camera. I used loopback to stream the monitor audio along with the virtual cam to a discord video and everyone watched that. I was looking at the recordings and the recordings now have this weird clipping.
I started recording audio directly from the mics after I noticed this issue, but I also want to see if anyone has any way to possibly repair the audio.
I had multiple scenes but only one was in use the whole time. I'm using the NDI plugin to take in the camera input. I used source record and the regular obs recording option and both had issues, though the monitor audio had zero issues, no clipping and no audio drops. So I'm not sure what happened when I choose to record. I originally used recordings with default settings with the x286 encoder but switched to one of the apple hardware ones at that seemed to run a little smoother.
I tried adjust the specific audio source/tracks for the source record but that seemed to do nothing.
I have all default/global audio capture devices disabled. The mic recording is sent along with the camera over NDI rather having its own source. (The source was in there but Its not active for any of the recordings I just left it incase I wanted to switch to on device recording)
  • 2025-09-21 12-38-31.txt
  • 2025-09-21 12-56-40.txt
  • 2025-09-21 12-57-27.txt
  • 2025-09-21 13-03-33.txt
  • 2025-09-21 13-04-24.txt
  • 2025-09-21 13-44-41.txt
