Question / Help audio problems, desync? (live gamer portable)
rizl4
Thanks jim you're a star if you could get this one sorted yeah i didnt know usb 2.0 would cause such problems
i guess reasons its portable they wanted it to work on laptops
never understand why they wouldn't have 2 ports usb 2 and 3
stelzig
Really amazing that you're going so far to fix this, huge props :)
I actually looked at 3.0 USB capture cards first (well just the intensity shutte, have never seen others) and I heard that one was very picky so you couldn't be sure it would work even if you had USB 3.0 so I decided against it, heh.
Lanscaper
I too am having the same issues through the 3.5mm audio jack and the hdmi audio.
Is this just because this is a USB 2.0 device or would I have the same problem with the internal Live Gamer Pro card?
I haven't noticed the audio desync when using x-split though I surely need to do more testing.
jiveturkey600
Hey guys, Ive came up with a TEMPORARY solution until AVERMEDIA gives us an update.
Go into your LGP stream engine and turn your bitrate to 1.0mbps ..... then 2 then 3 and keep testing out your audio..... mines work at 5.0 at 25 fps....
SAD but yeah.
It also works at 30 fps at 1.0MBPS .... I hope avermedia solves this problem fast... because its the same on xsplit.
Feel free to tell me if you found a BETTER solution because i need it .
GOOGLE ME: Jiveturkey600
jiveturkey600
Heres an Update.....works PERFECT.... Downgrade your Quality to 1600-900 (Im streaming a gaming PC to a Streaming PC)
and if your Console just Dumb down your 1080p to 720p i can run..... 10.0MBPS and 30Fps Looks great.
