So whenever I preview/record/stream a scene with any audio being played (music, game sounds, youtube), I get random, annoying popping/skipping sounds that almost sound like clipping. This seems to only occur on my end, as the recordings sound just fine.
My equipment is as follows:
Any and all suggestions are appreciated!
Log:
- Logitech C615 Webcam
- Blue Snowball USB Mic
- M-Audio Firewire 410 Audio Interface
Log:
00:51:02: Open Broadcaster Software v0.654b - 32bit (´・ω・`)
00:51:02: -------------------------------
00:51:02: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
00:51:02: CPU Speed: 3300MHz
00:51:02: Physical Memory: 4095MB Total, 4095MB Free
00:51:02: stepping id: 7, model 42, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
00:51:02: monitor 1: pos={0, 0}, size={1920, 1080}
00:51:02: monitor 2: pos={1920, 0}, size={1920, 1080}
00:51:02: Windows Version: 6.1 Build 7601 (revision 18869)
00:51:02: Aero is Disabled
00:51:02: OBS Modules:
00:51:02: Base Address Module
00:51:02: 00E20000 OBS.exe
00:51:02: 6A170000 OBSApi.dll
00:51:02: 74230000 DShowPlugin.dll
00:51:02: 74180000 GraphicsCapture.dll
00:51:02: 74150000 NoiseGate.dll
00:51:02: 74640000 PSVPlugin.dll
00:51:02: 73D20000 scenesw.dll
00:51:02: ------------------------------------------
00:51:02: Adapter 1
00:51:02: Video Adapter: NVIDIA GeForce GTX 560 Ti
00:51:02: Video Adapter Dedicated Video Memory: 1027014656
00:51:02: Video Adapter Shared System Memory: 3221106688
00:51:02: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
00:51:02: Video Adapter Output 2: pos={1920, 0}, size={1920, 1080}, attached=true
00:51:02: =====Stream Start: 2015-08-03, 00:51:02===============================================
00:51:02: Multithreaded optimizations: On
00:51:02: Base resolution: 1920x1080
00:51:02: Output resolution: 1280x720
00:51:02: Loading up D3D10 on NVIDIA GeForce GTX 560 Ti (Adapter 1)...
00:51:02: Audio Format: 48000 Hz
00:51:02: Audio Channels: 2 Ch
00:51:02: Playback device {0.0.0.00000000}.{7e76fd13-9037-4f2c-b68c-abdbc41c7911}
00:51:02: Using desktop audio input: MAIN (M-Audio FW 410)
00:51:02: Global Audio time adjust: 0
00:51:02: Using auxilary audio input: Microphone (Blue Snowball)
00:51:02: Mic time offset: 0
00:51:02: Audio Encoding: AAC
00:51:02: bitrate: 128
00:51:02: device: Logitech HD Webcam C615,
00:51:02: device id \\?\usb#vid_046d&pid_082c&mi_02#7&1ebf6ad1&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
00:51:02: chosen type: RGB24, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000
00:51:02: use buffering: true - 10000, fourCC: 00000000
00:51:02: audio device: Disable,
00:51:02: audio device id Disabled,
00:51:02: audio time offset 0,
00:51:02:
00:51:02: Using directshow input
00:51:02: Scene buffering time set to 700
00:51:02: Video Encoding: x264
00:51:02: fps: 60
00:51:02: width: 1280, height: 720
00:51:02: preset: veryfast
00:51:02: profile: main
00:51:02: keyint: 120
00:51:02: CBR: yes
00:51:02: CFR: yes
00:51:02: max bitrate: 3300
00:51:02: buffer size: 3300
00:57:41: ------------------------------------------
00:57:41: device: Logitech HD Webcam C615,
00:57:41: device id \\?\usb#vid_046d&pid_082c&mi_02#7&1ebf6ad1&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
00:57:41: chosen type: RGB24, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000
00:57:41: use buffering: true - 10000, fourCC: 00000000
00:57:41: audio device: Disable,
00:57:41: audio device id Disabled,
00:57:41: audio time offset 0,
00:57:41:
00:57:41: Using directshow input
01:00:48: FlushBufferedVideo: Flushing 27 packets over 434 ms
01:00:48: Total frames encoded: 35129, total frames duplicated: 224 (0.64%)
01:00:48: Total frames rendered: 35122, number of late frames: 3 (0.01%) (it's okay for some frames to be late)
01:00:49:
01:00:49: Profiler time results:
01:00:49:
01:00:49: ==============================================================
01:00:49: video thread frame - [100%] [avg time: 1.495 ms] [children: 68.8%] [unaccounted: 31.2%]
01:00:49: | scene->Preprocess - [49.8%] [avg time: 0.745 ms]
01:00:49: | GPU download and conversion - [19%] [avg time: 0.284 ms] [children: 18.3%] [unaccounted: 0.736%]
01:00:49: | | flush - [17.7%] [avg time: 0.264 ms]
01:00:49: | | CopyResource - [0.401%] [avg time: 0.006 ms]
01:00:49: | | conversion to 4:2:0 - [0.201%] [avg time: 0.003 ms]
01:00:49: Convert444Threads - [100%] [avg time: 0.549 ms] [children: 98.5%] [unaccounted: 1.46%]
01:00:49: | Convert444toNV12 - [98.5%] [avg time: 0.541 ms]
01:00:49: encoder thread frame - [100%] [avg time: 0.826 ms] [children: 0.363%] [unaccounted: 99.6%]
01:00:49: | sending stuff out - [0.363%] [avg time: 0.003 ms]
01:00:49:
01:00:49:
01:00:49: Profiler CPU results:
01:00:49:
01:00:49: video thread frame - [cpu time: avg 0.819 ms, total 28797.8 ms] [avg calls per frame: 1]
01:00:49: | scene->Preprocess - [cpu time: avg 0.575 ms, total 20202.1 ms] [avg calls per frame: 1]
01:00:49: | GPU download and conversion - [cpu time: avg 0.077 ms, total 2714.41 ms] [avg calls per frame: 1]
01:00:49: | | flush - [cpu time: avg 0.067 ms, total 2386.81 ms] [avg calls per frame: 1]
01:00:49: | | CopyResource - [cpu time: avg 0.003 ms, total 109.2 ms] [avg calls per frame: 1]
01:00:49: | | conversion to 4:2:0 - [cpu time: avg 0.002 ms, total 78 ms] [avg calls per frame: 1]
01:00:49: Convert444Threads - [cpu time: avg 0.292 ms, total 20514.1 ms] [avg calls per frame: 2]
01:00:49: | Convert444toNV12 - [cpu time: avg 0.289 ms, total 20342.5 ms] [avg calls per frame: 2]
01:00:49: encoder thread frame - [cpu time: avg 0.142 ms, total 4992.03 ms] [avg calls per frame: 1]
01:00:49: | sending stuff out - [cpu time: avg 0 ms, total 15.6 ms] [avg calls per frame: 1]
01:00:49:
01:00:49: =====Stream End: 2015-08-03, 01:00:49=================================================
