deja-vu-meter
I cannot get a log right now because the event is still streaming on another computer. We got complaints about no audio in the stream but the audio meter indicated input was OK and we had not changed anything except the update. We were not behind on updates so it was not a huge leap when we updated. We re-added the audio source and it came back for a bit. What had changed is that I went into the audio and changed from Monitor off to Monitor and output. After some tense back and forth it does seem like "monitor and output" no longer works. I ended up duplicating the audio source and on one copy I have monitor off and the other is monitor no output.
When I am able and not working an event, I will do more testing to confirm and add logs and some other details. I wanted to get this started though to see if anyone else had noticed this or could confirm already. Thank you.
