Audio/Mic Issue
OBS detects my microphone perfectly fine, but won't take any audio from it at all. I've restarted it, reinstalled it, checked all my audio tracks, checked windows usage settings, and modified any other audio settings related to similar issues I've found on here. Nothing works. If anyone has had a similar issue or the same issue then your help would be greatly appreciated.
A log file is needed. Look at the pinned posts on how to get it.
Do the mic works on other apps / programs? Do you see the vu meter in OBS move when you speak on the mic? Did you unintentionally muted it?
Yeah, Mic works on Roblox, Discord etc. The meter doesn't move at all when I speak and I've made sure everything isn't muted. Once I get it do you want me to send the log file here?
