Question / Help Audio is out of sync and I can't fix it
Engima
So my webcam and mic are out of sync and when I add a delay to fix it, it doesnt do anything! I really need help with this because its very VERY annoying
I keep trying to fix it and change it, then when i put it into sony vegas I can tell the delay is the exact same time, I'll try now
06:23:45: Using auxilary audio input: Headset Microphone (6- ASTRO MixAmp Pro )
06:23:45: Mic time offset: 0
Your mic is not offset, what value are you trying to offset the audio by?
I'm trying to use my blue yeti and there shouldnt be a delay right if I am using my webcam with no delay
if only it worked that way... Depending on your setup, there may be delay. I would try delaying the audio by 100MS at a time until it syncs up
Perfect! Depending on the webcam, sometimes there is a delay before OBS ever even gets the feed. In this case, adjusting the audio is the best option
