PKsillo
Ok so searching and searching for a fix for one of my 2 problems and I didnt found any solution...
The only solution I fould for QuickSync is change to Windows 8 and for the X264 no solution found..
Ok so here we go with my rig first:
Case: Corsair Air 540
Power Supply: Corsair AX1200
OS: Microsoft Windows 7 Ultimate
Motherboard: Asus Maximus VI Hero
CPU: Intel Core i7 4770k @ 4.5 OC
Memory: 16 GB Corsair Dominator Platinum
Hard Drive: WD Caviar Black 1 TB
SSD: Samsung EVO 840 250GB / HDD
Video Card: EVGA GTX 780 SC ACX
Sound Card: Supreme FX
Headphones: Plantronics Audio 777
Monitor: Samsung BenQ 2720T
Mouse: SteelSeries Rival
Mousepad: SteelSeries QcK Heavy
Keyboard: Corsair K70 RGB Cherry MX Red
And now my problems:
[X264 Problem]
When I try to stream CS:GO or any other game my in-game fps performance is horrible... In CS:GO for example my fps on the menu if I just move the mouse they drop to 70-90 playing... they drop to those levels too... If i stop streaming my fps with fps_max 0 can go to 500-600 without a problem, this problem is been happening to me since like 2 months ago, before that I was able to stream on X264 without any kind of problem...
The log: http://pastebin.com/AEdqW7BZ
[QuickSync Problem]
The obvious QuickSync was killed, encoded failed YES I have Windows 7.
The log: http://pastebin.com/RNd4EKyf
If any of you guys give me a fix for my problems I will travel to your location and kiss you till you die..
Thanks in advance.
[X264 Problem]
[QuickSync Problem]
Thanks in advance.
