Question / Help Will Pay For Help!
Wolfsey
I can't seem to get my OBS working, When I open up the Elgato Program, I can perfectly stream to Twitch. But once I open up OBS and I preview stream or every click stream BOTH my TV and OBS go black, I have to stop the preview stream to obviously bring back my TV and OBS from getting a black screen, I was like, Alright, Let's move on to XSplit. Exact same thing. To find a solution quicker, Yes, Elgato is under a global source, I'm running a 32 Bit OBS.
Here are my logs.
07:21:04: Open Broadcaster Software v0.655b - 32bit (´・ω・`)
07:21:04: -------------------------------
07:21:04: CPU Name: Intel(R) Celeron(R) CPU N2840 @ 2.16GHz
07:21:04: CPU Speed: 2167MHz
07:21:04: Physical Memory: 3982MB Total, 2616MB Free
07:21:04: stepping id: 8, model 55, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 2, total cores 2
07:21:04: monitor 1: pos={0, 0}, size={1366, 768}
07:21:04: Windows Version: 10.0 Build 10240 (revision 16384)
07:21:04: Aero is Enabled
07:21:04: OBS Modules:
07:21:04: Base Address Module
07:21:04: 002C0000 OBS.exe
07:21:04: 72820000 OBSApi.dll
07:21:04: 73E20000 DShowPlugin.dll
07:21:04: 74000000 GraphicsCapture.dll
07:21:04: 73DF0000 NoiseGate.dll
07:21:04: 72420000 PSVPlugin.dll
07:21:04: 72400000 scenesw.dll
07:21:04: ------------------------------------------
07:21:04: Adapter 1
07:21:04: Video Adapter: Intel(R) HD Graphics
07:21:04: Video Adapter Dedicated Video Memory: 67108864
07:21:04: Video Adapter Shared System Memory: 1811939328
07:21:04: Video Adapter Output 1: pos={0, 0}, size={1366, 768}, attached=true
07:21:04: =====Stream Start: 2015-09-06, 07:21:04===============================================
07:21:04: Multithreaded optimizations: On
07:21:04: Base resolution: 1280x720
07:21:04: Output resolution: 1280x720
07:21:04: Loading up D3D10 on Intel(R) HD Graphics (Adapter 1)...
07:21:04: Audio Format: 48000 Hz
07:21:04: Audio Channels: 2 Ch
07:21:04: Playback device Default
07:21:04: Using desktop audio input: Speakers (Realtek High Definition Audio)
07:21:04: Global Audio time adjust: 0
07:21:04: Audio Encoding: AAC
07:21:04: bitrate: 128
07:21:04: device: Elgato Game Capture HD,
07:21:04: device id {39F50F4C-99E1-464A-B6F9-D605B4FB5918},
07:21:04: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
07:21:04: use buffering: true - 0, fourCC: 'UYVY'
07:21:04: audio device: Disable,
07:21:04: audio device id Disabled,
07:21:04: audio time offset 0,
07:21:04:
07:21:05: Elgato Game Capture: force buffering with 1 msec
07:21:11: Using directshow input
07:21:11: Scene buffering time set to 700
07:21:11: ------------------------------------------
07:21:11: Video Encoding: x264
07:21:11: fps: 30
07:21:11: width: 1280, height: 720
07:21:11: preset: veryfast
07:21:11: profile: main
07:21:11: keyint: 60
07:21:11: CBR: yes
07:21:11: CFR: yes
07:21:11: max bitrate: 1800
07:21:11: buffer size: 1800
07:21:23: FlushBufferedVideo: Flushing 5 packets over 133 ms
07:21:23: Total frames encoded: 334, total frames duplicated: 132 (39.52%)
07:21:23: Number of frames skipped due to encoder lag: 109 (32.63%)
07:21:23: Total frames rendered: 243, number of late frames: 9 (3.70%) (it's okay for some frames to be late)
07:21:27:
07:21:27: Profiler time results:
07:21:27:
07:21:27: ==============================================================
07:21:27: video thread frame - [100%] [avg time: 4.244 ms] [children: 61.6%] [unaccounted: 38.4%]
07:21:27: | scene->Preprocess - [36%] [avg time: 1.527 ms]
07:21:27: | GPU download and conversion - [25.6%] [avg time: 1.087 ms] [children: 12.7%] [unaccounted: 12.9%]
07:21:27: | | flush - [5.4%] [avg time: 0.229 ms]
07:21:27: | | CopyResource - [7.14%] [avg time: 0.303 ms]
07:21:27: | | conversion to 4:2:0 - [0.212%] [avg time: 0.009 ms]
07:21:27: Convert444Thread - [100%] [avg time: 3.407 ms] [children: 99.1%] [unaccounted: 0.881%]
07:21:27: | Convert444toNV12 - [99.1%] [avg time: 3.377 ms]
07:21:27: encoder thread frame - [100%] [avg time: 20.085 ms] [children: 0.0846%] [unaccounted: 99.9%]
07:21:27: | sending stuff out - [0.0846%] [avg time: 0.017 ms]
07:21:27:
07:21:27:
07:21:27: Profiler CPU results:
07:21:27:
07:21:27: video thread frame - [cpu time: avg 2.764 ms, total 671.875 ms] [avg calls per frame: 1]
07:21:27: | scene->Preprocess - [cpu time: avg 1.221 ms, total 296.875 ms] [avg calls per frame: 1]
07:21:27: | GPU download and conversion - [cpu time: avg 0.45 ms, total 109.375 ms] [avg calls per frame: 1]
07:21:27: | | flush - [cpu time: avg 0.321 ms, total 78.125 ms] [avg calls per frame: 1]
07:21:27: | | CopyResource - [cpu time: avg 0.071 ms, total 15.625 ms] [avg calls per frame: 1]
07:21:27: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
07:21:27: Convert444Thread - [cpu time: avg 2.354 ms, total 515.625 ms] [avg calls per frame: 1]
07:21:27: | Convert444toNV12 - [cpu time: avg 2.211 ms, total 484.375 ms] [avg calls per frame: 1]
07:21:27: encoder thread frame - [cpu time: avg 3.324 ms, total 1093.75 ms] [avg calls per frame: 1]
07:21:27: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
07:21:27:
07:21:27: =====Stream End: 2015-09-06, 07:21:27=================================================
07:21:33: Failed loading CUDA dll
