Question / Help Weird stuttering problems..
This is a longer Log with a 20 Minutes Game.
Well sometimes i have some laggspikes ingame and its not the same feeling without OBS.
17:30:01: Open Broadcaster Software v0.542b - 64bit ( ^ω^)
17:30:01: -------------------------------
17:30:01: CPU Name: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
17:30:01: CPU Speed: 3392MHz
17:30:01: Physical Memory:  8173MB Total, 5098MB Free
17:30:01: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
17:30:01: monitor 1: pos={1920, -84}, size={1680, 1050}
17:30:01: monitor 2: pos={0, 0}, size={1920, 1080}
17:30:01: Windows Version: 6.1 Build 7601 S
17:30:01: Aero is Disabled
17:30:01: OBS Modules:
17:30:01: Base Address     Module
17:30:01: 000000003F220000 OBS.exe
17:30:01: 00000000EE780000 OBSApi.dll
17:30:01: 00000000F7F90000 DShowPlugin.dll
17:30:01: 00000000F7F60000 GraphicsCapture.dll
17:30:01: 00000000F7EB0000 NoiseGate.dll
17:30:01: 00000000F3260000 PSVPlugin.dll
17:30:01: 00000000F3170000 scenesw.dll
17:30:01: ------------------------------------------
17:30:01: Adapter 1
17:30:01:   Video Adapter: NVIDIA GeForce GTX 550 Ti
17:30:01:   Video Adapter Dedicated Video Memory: 1025179648
17:30:01:   Video Adapter Shared System Memory: 3221106688
17:30:01: =====Stream Start: 2013-08-07, 17:30:01===============================================
17:30:01:   Multithreaded optimizations: On
17:30:01:   Base resolution: 1920x1080
17:30:01:   Output resolution: 1280x720
17:30:01: Loading up D3D10...
17:30:02: Playback device Default
17:30:02: ------------------------------------------
17:30:02: Using desktop audio input: Headset (SB Tactic3D Rage USB)
17:30:02: Using auxilary audio input: Headset Microphone (SB Tactic3D Rage USB)
17:30:02: Audio Encoding: AAC
17:30:02:     bitrate: 128
17:30:02: Using graphics capture
17:30:02: Video Encoding: x264
17:30:02:     fps: 60
17:30:02:     width: 1280, height: 720
17:30:02:     preset: veryfast
17:30:02:     CBR: yes
17:30:02:     CFR: no
17:30:02:     max bitrate: 3000
17:30:03: Using RTMP service: Twitch / Justin.tv
17:30:03:   Server selection: rtmp://live-fra.justin.tv/app
17:30:04: librtmp error: rtmp://live-fra.justin.tv/app:
17:30:04: NetStream.Publish.Rejected (Authentication Failed.)
17:30:04: Connection to rtmp://live-fra.justin.tv/app failed: Streamkanal oder Streamschlüssel ungültig
17:30:04:
17:30:04: rtmp://live-fra.justin.tv/app:
17:30:04:
17:30:04: Total frames rendered: 144, number of frames that lagged: 1 (0.69%) (it's okay for some frames to lag)
17:30:04: Number of times waited to send: 0, Waited for a total of 0 bytes
17:30:04: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
17:30:04: =====Stream End: 2013-08-07, 17:30:04=================================================
17:32:58: =====Stream Start: 2013-08-07, 17:32:58===============================================
17:32:58:   Multithreaded optimizations: On
17:32:58:   Base resolution: 1920x1080
17:32:58:   Output resolution: 1280x720
17:32:58: ------------------------------------------
17:32:58: Loading up D3D10...
17:32:58: Playback device Default
17:32:58: Using desktop audio input: Headset (SB Tactic3D Rage USB)
17:32:58: Using auxilary audio input: Headset Microphone (SB Tactic3D Rage USB)
17:32:58: Audio Encoding: AAC
17:32:58:     bitrate: 128
17:32:58: Using graphics capture
17:32:58: Video Encoding: x264
17:32:58:     fps: 60
17:32:58:     width: 1280, height: 720
17:32:58:     preset: veryfast
17:32:58:     CBR: yes
17:32:58:     CFR: no
17:32:58:     max bitrate: 3000
17:33:00: Using RTMP service: Twitch / Justin.tv
17:33:00:   Server selection: rtmp://live-fra.justin.tv/app
17:33:01: librtmp error: rtmp://live-fra.justin.tv/app:
17:33:01: NetStream.Publish.Rejected (Authentication Failed.)
17:33:01: Connection to rtmp://live-fra.justin.tv/app failed: Streamkanal oder Streamschlüssel ungültig
17:33:01:
17:33:01: rtmp://live-fra.justin.tv/app:
17:33:01:
17:33:01: Total frames rendered: 145, number of frames that lagged: 1 (0.69%) (it's okay for some frames to lag)
17:33:01: Number of times waited to send: 0, Waited for a total of 0 bytes
17:33:01: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
17:33:01: =====Stream End: 2013-08-07, 17:33:01=================================================
17:33:10: =====Stream Start: 2013-08-07, 17:33:10===============================================
17:33:10:   Multithreaded optimizations: On
17:33:10:   Base resolution: 1920x1080
17:33:10:   Output resolution: 1280x720
17:33:10: ------------------------------------------
17:33:10: Loading up D3D10...
17:33:10: Playback device Default
17:33:10: Using desktop audio input: Headset (SB Tactic3D Rage USB)
17:33:10: Using auxilary audio input: Headset Microphone (SB Tactic3D Rage USB)
17:33:10: Audio Encoding: AAC
17:33:10:     bitrate: 128
17:33:10: Using Monitor Capture
17:33:11: ------------------------------------------
17:33:11: Video Encoding: x264
17:33:11:     fps: 60
17:33:11:     width: 1280, height: 720
17:33:11:     preset: veryfast
17:33:11:     CBR: yes
17:33:11:     CFR: no
17:33:11:     max bitrate: 3000
17:33:12: Using RTMP service: Twitch / Justin.tv
17:33:12:   Server selection: rtmp://live-fra.justin.tv/app
17:33:13: librtmp error: rtmp://live-fra.justin.tv/app:
17:33:13: NetStream.Publish.Rejected (Authentication Failed.)
17:33:13: Connection to rtmp://live-fra.justin.tv/app failed: Streamkanal oder Streamschlüssel ungültig
17:33:13:
17:33:13: rtmp://live-fra.justin.tv/app:
17:33:13:
17:33:13: Total frames rendered: 135, number of frames that lagged: 2 (1.48%) (it's okay for some frames to lag)
17:33:13: Number of times waited to send: 0, Waited for a total of 0 bytes
17:33:13: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
17:33:13: =====Stream End: 2013-08-07, 17:33:13=================================================
17:34:13: =====Stream Start: 2013-08-07, 17:34:13===============================================
17:34:13:   Multithreaded optimizations: On
17:34:13:   Base resolution: 1920x1080
17:34:13:   Output resolution: 1280x720
17:34:13: ------------------------------------------
17:34:13: Loading up D3D10...
17:34:14: Playback device Default
17:34:14: ------------------------------------------
17:34:14: Using desktop audio input: Headset (SB Tactic3D Rage USB)
17:34:14: Using auxilary audio input: Headset Microphone (SB Tactic3D Rage USB)
17:34:14: Audio Encoding: AAC
17:34:14:     bitrate: 128
17:34:14: Using Monitor Capture
17:34:14: Video Encoding: x264
17:34:14:     fps: 60
17:34:14:     width: 1280, height: 720
17:34:14:     preset: veryfast
17:34:14:     CBR: yes
17:34:14:     CFR: no
17:34:14:     max bitrate: 3000
17:34:15: Using RTMP service: Twitch / Justin.tv
17:34:15:   Server selection: rtmp://live-ams.justin.tv/app
17:34:16: librtmp error: rtmp://live-ams.justin.tv/app:
17:34:16: NetStream.Publish.Rejected (Authentication Failed.)
17:34:16: Connection to rtmp://live-ams.justin.tv/app failed: Streamkanal oder Streamschlüssel ungültig
17:34:16:
17:34:16: rtmp://live-ams.justin.tv/app:
17:34:16:
17:34:16: Total frames rendered: 141, number of frames that lagged: 1 (0.71%) (it's okay for some frames to lag)
17:34:16: Number of times waited to send: 0, Waited for a total of 0 bytes
17:34:16: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
17:34:16: =====Stream End: 2013-08-07, 17:34:16=================================================
17:35:31: =====Stream Start: 2013-08-07, 17:35:31===============================================
17:35:31:   Multithreaded optimizations: On
17:35:31:   Base resolution: 1920x1080
17:35:31:   Output resolution: 1280x720
17:35:31: ------------------------------------------
17:35:31: Loading up D3D10...
17:35:31: Playback device Default
17:35:32: ------------------------------------------
17:35:32: Using desktop audio input: Headset (SB Tactic3D Rage USB)
17:35:32: Using auxilary audio input: Headset Microphone (SB Tactic3D Rage USB)
17:35:32: Audio Encoding: AAC
17:35:32:     bitrate: 128
17:35:32: Using Monitor Capture
17:35:32: Video Encoding: x264
17:35:32:     fps: 60
17:35:32:     width: 1280, height: 720
17:35:32:     preset: veryfast
17:35:32:     CBR: yes
17:35:32:     CFR: no
17:35:32:     max bitrate: 3000
17:35:33: Using RTMP service: Twitch / Justin.tv
17:35:33:   Server selection: rtmp://live-fra.justin.tv/app
17:35:34: librtmp error: rtmp://live-fra.justin.tv/app:
17:35:34: NetStream.Publish.Rejected (Authentication Failed.)
17:35:34: Connection to rtmp://live-fra.justin.tv/app failed: Streamkanal oder Streamschlüssel ungültig
17:35:34:
17:35:34: rtmp://live-fra.justin.tv/app:
17:35:34:
17:35:34: Total frames rendered: 145, number of frames that lagged: 1 (0.69%) (it's okay for some frames to lag)
17:35:34: Number of times waited to send: 0, Waited for a total of 0 bytes
17:35:34: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
17:35:34: =====Stream End: 2013-08-07, 17:35:34=================================================
17:36:31: =====Stream Start: 2013-08-07, 17:36:31===============================================
17:36:31:   Multithreaded optimizations: On
17:36:31:   Base resolution: 1920x1080
17:36:31:   Output resolution: 1280x720
17:36:31: ------------------------------------------
17:36:31: Loading up D3D10...
17:36:31: Playback device Default
17:36:31: Using desktop audio input: Headset (SB Tactic3D Rage USB)
17:36:31: Using auxilary audio input: Headset Microphone (SB Tactic3D Rage USB)
17:36:31: Audio Encoding: AAC
17:36:31:     bitrate: 128
17:36:31: Using Monitor Capture
17:36:31: Video Encoding: x264
17:36:31:     fps: 60
17:36:31:     width: 1280, height: 720
17:36:31:     preset: veryfast
17:36:31:     CBR: yes
17:36:31:     CFR: no
17:36:31:     max bitrate: 3000
17:36:32: Using RTMP service: Twitch / Justin.tv
17:36:32:   Server selection: rtmp://live-fra.justin.tv/app
17:36:34: SO_SNDBUF was at 8192
17:36:34: SO_SNDBUF is now 65536
17:36:56: Using graphics capture
17:36:58: Using Monitor Capture
17:37:05: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:37:05:   New Scene
17:37:13: Using Monitor Capture
17:37:17: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:37:17:   New Scene
17:37:17: Using graphics capture
17:37:18: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:37:18:   New Scene
17:37:18: Using Monitor Capture
17:37:28: Total frames rendered: 3373, number of frames that lagged: 2 (0.06%) (it's okay for some frames to lag)
17:37:28: RTMPPublisher::SocketLoop: Aborting due to bStopping
17:37:28: Number of times waited to send: 0, Waited for a total of 0 bytes
17:37:28: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
17:37:28: =====Stream End: 2013-08-07, 17:37:28=================================================
17:37:32: =====Stream Start: 2013-08-07, 17:37:32===============================================
17:37:32:   Multithreaded optimizations: On
17:37:32:   Base resolution: 1920x1080
17:37:32:   Output resolution: 1280x720
17:37:32: ------------------------------------------
17:37:32: Loading up D3D10...
17:37:32: Playback device Default
17:37:32: Using desktop audio input: Headset (SB Tactic3D Rage USB)
17:37:32: Using auxilary audio input: Headset Microphone (SB Tactic3D Rage USB)
17:37:32: Audio Encoding: AAC
17:37:32:     bitrate: 128
17:37:32: Using Monitor Capture
17:37:32: Video Encoding: x264
17:37:32:     fps: 60
17:37:32:     width: 1280, height: 720
17:37:32:     preset: veryfast
17:37:32:     CBR: yes
17:37:32:     CFR: no
17:37:32:     max bitrate: 3000
17:37:33: Using RTMP service: Twitch / Justin.tv
17:37:33:   Server selection: rtmp://live-fra.justin.tv/app
17:37:35: SO_SNDBUF was at 8192
17:37:35: SO_SNDBUF is now 65536
17:42:20: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:42:20:   New Scene
17:42:20: Using graphics capture
17:42:21: SharedTexCapture hooked
17:42:25: SharedTexCapture hooked
18:07:27: Exit signal received, terminating capture
18:07:30: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
18:07:30:   New Scene
18:07:30: Using Monitor Capture
18:07:36: Total frames rendered: 108161, number of frames that lagged: 29 (0.03%) (it's okay for some frames to lag)
18:07:36: RTMPPublisher::SocketLoop: Aborting due to loop exit
18:07:36: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
18:07:36: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
18:07:36: Number of times waited to send: 0, Waited for a total of 0 bytes
18:07:36: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
18:07:36: =====Stream End: 2013-08-07, 18:07:36=================================================
18:07:37:
18:07:37: Profiler results:
18:07:37:
18:07:37: ==============================================================
18:07:37: frame - [100%] [avg time: 2.591 ms (cpu time: avg 2.053 ms, total 230491 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.116%]
18:07:37: | frame preprocessing and rendering - [40.5%] [avg time: 1.05 ms (cpu time: avg 0.753 ms, total 84521.4 ms)] [avg calls per frame: 1] [children: 23.1%] [unaccounted: 17.4%]
18:07:37: | | scene->Preprocess - [23.1%] [avg time: 0.599 ms (cpu time: avg 0.395 ms, total 44397.9 ms)] [avg calls per frame: 1]
18:07:37: | video encoding and uploading - [59.4%] [avg time: 1.538 ms (cpu time: avg 1.298 ms, total 145767 ms)] [avg calls per frame: 1] [children: 58.4%] [unaccounted: 1%]
18:07:37: | | flush - [7.29%] [avg time: 0.189 ms (cpu time: avg 0.063 ms, total 7098.04 ms)] [avg calls per frame: 1]
18:07:37: | | CopyResource - [0.618%] [avg time: 0.016 ms (cpu time: avg 0.01 ms, total 1232.41 ms)] [avg calls per frame: 0]
18:07:37: | | conversion to 4:2:0 - [0.618%] [avg time: 0.016 ms (cpu time: avg 0.003 ms, total 390.006 ms)] [avg calls per frame: 0]
18:07:37: | | call to encoder - [48.8%] [avg time: 1.264 ms (cpu time: avg 1.194 ms, total 134020 ms)] [avg calls per frame: 0]
18:07:37: | | sending stuff out - [1.04%] [avg time: 0.027 ms (cpu time: avg 0.015 ms, total 1684.81 ms)] [avg calls per frame: 0]
18:07:37: | Convert444Threads - [1.28e+003%] [avg time: 33.289 ms (cpu time: avg 1.301 ms, total 146048 ms)] [avg calls per frame: 1]
18:07:37:
well i can only tell you what i see ^^ and i have laggs but well if theres nothing you can find then its ok for me
