Hi guys, I have only been using OBS for a short amount of time. Whenever I watch my gameplay that OBS has captured it is very choppy and the audio sounds out of place.
The Log:
18:57:46.214: CPU Name: AMD Ryzen 7 1700 Eight-Core Processor
18:57:46.214: CPU Speed: 2994MHz
18:57:46.214: Physical Cores: 4, Logical Cores: 8
18:57:46.214: Physical Memory: 16314MB Total, 11443MB Free
18:57:46.214: Windows Version: 10.0 Build 17134 (revision: 472; 64-bit)
18:57:46.214: Running as administrator: false
18:57:46.214: Aero is Enabled (Aero is always on for windows 8 and above)
18:57:46.214: Windows 10 Gaming Features:
18:57:46.214: Game Bar: Off
18:57:46.214: Game DVR: Off
18:57:46.214: Game DVR Background Recording: Off
18:57:46.216: Sec. Software Status:
18:57:46.218: Windows Defender Antivirus: disabled (AV)
18:57:46.218: McAfee VirusScan: enabled (AV)
18:57:46.218: McAfee Firewall: enabled (FW)
18:57:46.218: Windows Firewall: disabled (FW)
18:57:46.218: Windows Defender Antivirus: disabled (ASW)
18:57:46.218: McAfee VirusScan: enabled (ASW)
18:57:46.219: Portable mode: false
18:57:46.363: OBS 21.1.0 (64bit, windows)
18:57:46.363: ---------------------------------
18:57:46.364: ---------------------------------
18:57:46.364: audio settings reset:
18:57:46.364: samples per sec: 44100
18:57:46.364: speakers: 2
18:57:46.366: ---------------------------------
18:57:46.366: Initializing D3D11...
18:57:46.366: Available Video Adapters:
18:57:46.368: Adapter 1: Radeon RX 580 Series
18:57:46.368: Dedicated VRAM: 4274225152
18:57:46.368: Shared VRAM: 4258547712
18:57:46.368: output 1: pos={0, 0}, size={1920, 1080}, attached=true
18:57:46.371: Loading up D3D11 on adapter Radeon RX 580 Series (0)
18:57:46.412: D3D11 loaded successfully, feature level used: 45056
18:57:47.316: ---------------------------------
18:57:47.316: video settings reset:
18:57:47.316: base resolution: 1920x1080
18:57:47.316: output resolution: 1920x1080
18:57:47.316: downscale filter: Bicubic
18:57:47.316: fps: 60/1
18:57:47.316: format: NV12
18:57:47.316: YUV mode: 601/Partial
18:57:47.317: Audio monitoring device:
18:57:47.317: name: Default
18:57:47.317: id: default
18:57:47.317: ---------------------------------
18:57:47.319: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
18:57:47.321: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
18:57:47.689: [AMF] Version 2.3.3 loaded (Compiled: 1.4.4.0, Runtime: 1.4.10.0, Library: 1;4;10;0;18.40.11.10;201811301045;CL#1714408).
18:57:47.860: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
18:57:47.861: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
18:57:47.861: (127)
18:57:47.861: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
18:57:47.862: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
18:57:47.863: [browser_source: 'Version: 1.31.0']
18:57:47.866: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
18:57:47.866: (126)
18:57:48.028: Couldn't find VLC installation, VLC video source disabled
18:57:48.033: No blackmagic support
18:57:48.038: ---------------------------------
18:57:48.038: Loaded Modules:
18:57:48.038: win-wasapi.dll
18:57:48.038: win-mf.dll
18:57:48.038: win-dshow.dll
18:57:48.038: win-decklink.dll
18:57:48.038: win-capture.dll
18:57:48.038: vlc-video.dll
18:57:48.038: text-freetype2.dll
18:57:48.038: rtmp-services.dll
18:57:48.038: obs-x264.dll
18:57:48.038: obs-vst.dll
18:57:48.038: obs-transitions.dll
18:57:48.038: obs-text.dll
18:57:48.038: obs-qsv11.dll
18:57:48.038: obs-outputs.dll
18:57:48.038: obs-filters.dll
18:57:48.038: obs-ffmpeg.dll
18:57:48.038: obs-browser.dll
18:57:48.038: image-source.dll
18:57:48.038: frontend-tools.dll
18:57:48.038: enc-amf.dll
18:57:48.038: coreaudio-encoder.dll
18:57:48.038: ==== Startup complete ===============================================
18:57:48.043: All scene data cleared
18:57:48.043: ------------------------------------------------
18:57:48.124: WASAPI: Device 'Speakers (Logitech G533 Gaming Headset)' initialized
18:57:48.137: WASAPI: Device 'Microphone (Logitech G533 Gaming Headset)' initialized
18:57:48.144: WASAPI: Device 'Microphone (Logitech G533 Gaming Headset)' initialized
18:57:48.181: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
18:57:53.129: Switched to scene 'Scene'
18:57:53.129: [game-capture: 'Game Capture'] attempting to hook fullscreen process: explorer.exe
18:57:53.129: [game-capture: 'Game Capture'] cannot capture explorer.exe due to being blacklisted
18:57:53.129: ------------------------------------------------
18:57:53.129: Loaded scenes:
18:57:53.129: - scene 'Scene':
18:57:53.130: - source: 'Game Capture' (game_capture)
18:57:53.130: - source: 'Audio Input Capture' (wasapi_input_capture)
18:57:53.130: ------------------------------------------------
18:59:13.695: ==== Shutting down ==================================================
18:59:13.698: Switched to scene '(null)'
18:59:13.699: WASAPI: Device 'Microphone (Logitech G533 Gaming Headset)' Terminated
18:59:13.702: WASAPI: Device 'Speakers (Logitech G533 Gaming Headset)' Terminated
18:59:13.708: WASAPI: Device 'Microphone (Logitech G533 Gaming Headset)' Terminated
18:59:13.711: All scene data cleared
18:59:13.711: ------------------------------------------------
18:59:13.969: Freeing OBS context data
18:59:13.992: [Scripting] Total detached callbacks: 0
18:59:14.047: == Profiler Results =============================
18:59:14.047: run_program_init: 7350.99 ms
18:59:14.047: ┣OBSApp::AppInit: 23.418 ms
18:59:14.047: ┃ ┗OBSApp::InitLocale: 2.093 ms
18:59:14.047: ┗OBSApp::OBSInit: 7313 ms
18:59:14.047: ┣obs_startup: 5.284 ms
18:59:14.047: ┗OBSBasic::OBSInit: 6825.62 ms
18:59:14.047: ┣OBSBasic::InitBasicConfig: 0.763 ms
18:59:14.047: ┣OBSBasic::ResetAudio: 0.247 ms
18:59:14.047: ┣OBSBasic::ResetVideo: 952.596 ms
18:59:14.047: ┣OBSBasic::InitOBSCallbacks: 0.009 ms
18:59:14.047: ┣OBSBasic::InitHotkeys: 0.085 ms
18:59:14.047: ┣obs_load_all_modules: 720.749 ms
18:59:14.047: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.673 ms
18:59:14.047: ┃ ┣obs_init_module(enc-amf.dll): 525.34 ms
18:59:14.047: ┃ ┣obs_init_module(frontend-tools.dll): 3.85 ms
18:59:14.047: ┃ ┣obs_init_module(image-source.dll): 0.004 ms
18:59:14.047: ┃ ┣obs_init_module(obs-browser.dll): 0.123 ms
18:59:14.047: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.635 ms
18:59:14.047: ┃ ┃ ┗nvenc_check: 0.62 ms
18:59:14.047: ┃ ┣obs_init_module(obs-filters.dll): 0.014 ms
18:59:14.047: ┃ ┣obs_init_module(obs-outputs.dll): 0.008 ms
18:59:14.047: ┃ ┣obs_init_module(obs-qsv11.dll): 150.002 ms
18:59:14.047: ┃ ┣obs_init_module(obs-text.dll): 0.353 ms
18:59:14.047: ┃ ┣obs_init_module(obs-transitions.dll): 0.009 ms
18:59:14.047: ┃ ┣obs_init_module(obs-vst.dll): 0.003 ms
18:59:14.047: ┃ ┣obs_init_module(obs-x264.dll): 0.003 ms
18:59:14.047: ┃ ┣obs_init_module(rtmp-services.dll): 0.018 ms
18:59:14.047: ┃ ┣obs_init_module(text-freetype2.dll): 0.138 ms
18:59:14.047: ┃ ┣obs_init_module(vlc-video.dll): 0.057 ms
18:59:14.047: ┃ ┣obs_init_module(win-capture.dll): 0.189 ms
18:59:14.047: ┃ ┣obs_init_module(win-decklink.dll): 2.804 ms
18:59:14.047: ┃ ┣obs_init_module(win-dshow.dll): 2.199 ms
18:59:14.047: ┃ ┣obs_init_module(win-mf.dll): 0 ms
18:59:14.047: ┃ ┣obs_init_module(win-wasapi.dll): 0.006 ms
18:59:14.047: ┃ ┗reset_win32_symbol_paths: 0.129 ms
18:59:14.047: ┣OBSBasic::ResetOutputs: 0.728 ms
18:59:14.047: ┣OBSBasic::CreateHotkeys: 0.299 ms
18:59:14.047: ┣OBSBasic::InitService: 1.899 ms
18:59:14.047: ┣OBSBasic::InitPrimitives: 0.243 ms
18:59:14.047: ┗OBSBasic::Load: 5088.11 ms
18:59:14.047: obs_hotkey_thread(25 ms): min=0.003 ms, median=0.009 ms, max=15.737 ms, 99th percentile=0.194 ms, 100% below 25 ms
18:59:14.047: audio_thread(Audio): min=0 ms, median=0.122 ms, max=18.79 ms, 99th percentile=0.36 ms
18:59:14.047: obs_graphics_thread(16.6667 ms): min=0.198 ms, median=0.874 ms, max=4976.28 ms, 99th percentile=3.628 ms, 99.8776% below 16.667 ms
18:59:14.047: ┣tick_sources: min=0.002 ms, median=0.012 ms, max=4975.62 ms, 99th percentile=0.03 ms
18:59:14.047: ┣output_frame: min=0.192 ms, median=0.542 ms, max=19.046 ms, 99th percentile=1.613 ms
18:59:14.047: ┃ ┣gs_context(video->graphics): min=0.138 ms, median=0.198 ms, max=18.497 ms, 99th percentile=0.973 ms
18:59:14.047: ┃ ┃ ┣render_video: min=0.026 ms, median=0.075 ms, max=11.62 ms, 99th percentile=0.187 ms
18:59:14.047: ┃ ┃ ┃ ┣render_main_texture: min=0.005 ms, median=0.01 ms, max=0.228 ms, 99th percentile=0.024 ms
18:59:14.048: ┃ ┃ ┃ ┣render_output_texture: min=0.005 ms, median=0.029 ms, max=11.528 ms, 99th percentile=0.076 ms
18:59:14.048: ┃ ┃ ┃ ┣render_convert_texture: min=0.001 ms, median=0.015 ms, max=0.86 ms, 99th percentile=0.04 ms
18:59:14.048: ┃ ┃ ┃ ┗stage_output_texture: min=0 ms, median=0.012 ms, max=0.757 ms, 99th percentile=0.032 ms
18:59:14.048: ┃ ┃ ┣download_frame: min=0 ms, median=0.008 ms, max=10.707 ms, 99th percentile=0.021 ms
18:59:14.048: ┃ ┃ ┗gs_flush: min=0.031 ms, median=0.112 ms, max=18.34 ms, 99th percentile=0.575 ms
18:59:14.048: ┃ ┗output_video_data: min=0.262 ms, median=0.339 ms, max=2.126 ms, 99th percentile=0.609 ms
18:59:14.048: ┗render_displays: min=0 ms, median=0.313 ms, max=30.945 ms, 99th percentile=1.336 ms
18:59:14.048: video_thread(video): min=0.001 ms, median=0.001 ms, max=0.066 ms, 99th percentile=0.002 ms
18:59:14.048: =================================================
18:59:14.048: == Profiler Time Between Calls ==================
18:59:14.048: obs_hotkey_thread(25 ms): min=24.173 ms, median=25.009 ms, max=51.638 ms, 89.8592% within ±2% of 25 ms (0.718184% lower, 9.42258% higher)
18:59:14.048: obs_graphics_thread(16.6667 ms): min=1.264 ms, median=16.666 ms, max=4976.29 ms, 96.3885% within ±2% of 16.667 ms (1.87717% lower, 1.73434% higher)
18:59:14.073: Number of memory leaks: 1
Thanks for the help,
conzo
The Log:
18:57:47.861: (127)
18:57:47.866: (126)
conzo
