13:48:47: Open Broadcaster Software v0.584b - 32bit (´・ω・`)
13:48:47: -------------------------------
13:48:47: CPU Name: Intel(R) Core(TM) i7-3615QM CPU @ 2.30GHz
13:48:47: CPU Speed: 2294MHz
13:48:47: Physical Memory: 4095MB Total, 4095MB Free
13:48:47: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
13:48:47: monitor 1: pos={0, 0}, size={1920, 1200}
13:48:47: Windows Version: 6.1 Build 7601 S
13:48:47: Aero is Enabled
13:48:47: OBS Modules:
13:48:47: Base Address Module
13:48:47: 00F70000 OBS.exe
13:48:47: 60CE0000 OBSApi.dll
13:48:47: 6E8C0000 DShowPlugin.dll
13:48:47: 725D0000 GraphicsCapture.dll
13:48:47: 67F00000 NoiseGate.dll
13:48:47: 700D0000 PSVPlugin.dll
13:48:47: ------------------------------------------
13:48:47: Adapter 1
13:48:47: Video Adapter: NVIDIA GeForce GT 650M
13:48:47: Video Adapter Dedicated Video Memory: 1022033920
13:48:47: Video Adapter Shared System Memory: 3221221376
13:48:47: Video Adapter Output 1: pos={0, 0}, size={1920, 1200}, attached=true
13:48:47: =====Stream Start: 2013-11-29, 13:48:47===============================================
13:48:47: Multithreaded optimizations: On
13:48:47: Base resolution: 1280x720
13:48:47: Output resolution: 1280x720
13:48:47: Loading up D3D10 on NVIDIA GeForce GT 650M...
13:48:47: Audio Format: 48000hz
13:48:47: Playback device Default
13:48:47: Using desktop audio input: Speakers (Cirrus Logic CS4206B (AB 40))
13:48:47: Using quad speaker setup
13:48:47: Using auxilary audio input: Microphone (Blue Snowball)
13:48:47: Using Mic QPC timestamps
13:48:47: Audio Encoding: AAC
13:48:47: bitrate: 96
13:48:47: device: Logitech HD Webcam C615,
13:48:47: device id \\?\usb#vid_046d&pid_082c&mi_02#6&52dd137&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
13:48:47: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
13:48:47: use buffering: true - 15000000, fourCC: 'I420'
13:48:47: audio device: Disable,
13:48:47: audio device id Disabled,
13:48:47:
13:48:47: Using directshow input
13:48:47: Using bitmap image
13:48:47: device: Elgato Game Capture HD,
13:48:47: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
13:48:47: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
13:48:47: use buffering: false - 0, fourCC: 'UYVY'
13:48:47:
13:48:47: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
13:48:47: Scene buffering time set to 1500
13:48:47: Video Encoding: x264
13:48:47: fps: 30
13:48:47: width: 1280, height: 720
13:48:47: preset: veryfast
13:48:47: profile: high
13:48:47: keyint: 60
13:48:47: CBR: yes
13:48:47: CFR: no
13:48:47: max bitrate: 6000
13:48:47: buffer size: 6000
13:48:47: MMDeviceAudioSource: Frequency for device 'Speakers (Cirrus Logic CS4206B (AB 40))' is 768000, samples per sec is 48000
13:48:47: MMDeviceAudioSource: Frequency for device 'Microphone (Blue Snowball)' is 352800, samples per sec is 44100
14:14:48: Total frames encoded: 46764, total frames duplicated: 1226 (2.62%)
14:14:48: Number of frames skipped due to encoder lag: 21 (0.04%)
14:14:48: Total frames rendered: 46736, number of late frames: 14 (0.03%) (it's okay for some frames to be late)
14:14:51:
14:14:51: Profiler time results:
14:14:51:
14:14:51: ==============================================================
14:14:51: video thread frame - [100%] [avg time: 5.467 ms] [children: 68.3%] [unaccounted: 31.7%]
14:14:51: | scene->Preprocess - [60.4%] [avg time: 3.304 ms]
14:14:51: | GPU download and conversion - [7.9%] [avg time: 0.432 ms] [children: 6.88%] [unaccounted: 1.02%]
14:14:51: | | flush - [5.65%] [avg time: 0.309 ms]
14:14:51: | | CopyResource - [1.1%] [avg time: 0.06 ms]
14:14:51: | | conversion to 4:2:0 - [0.128%] [avg time: 0.007 ms]
14:14:51: Convert444Threads - [100%] [avg time: 1.015 ms] [children: 98.7%] [unaccounted: 1.28%]
14:14:51: | Convert444toNV12 - [98.7%] [avg time: 1.002 ms]
14:14:51: encoder thread frame - [100%] [avg time: 2.638 ms]
14:14:51:
14:14:51:
14:14:51: Profiler CPU results:
14:14:51:
14:14:51: video thread frame - [cpu time: avg 4.249 ms, total 198605 ms] [avg calls per frame: 1]
14:14:51: | scene->Preprocess - [cpu time: avg 2.756 ms, total 128841 ms] [avg calls per frame: 1]
14:14:51: | GPU download and conversion - [cpu time: avg 0.178 ms, total 8346.06 ms] [avg calls per frame: 1]
14:14:51: | | flush - [cpu time: avg 0.111 ms, total 5226.04 ms] [avg calls per frame: 1]
14:14:51: | | CopyResource - [cpu time: avg 0.019 ms, total 920.407 ms] [avg calls per frame: 1]
14:14:51: | | conversion to 4:2:0 - [cpu time: avg 0.005 ms, total 265.202 ms] [avg calls per frame: 1]
14:14:51: Convert444Threads - [cpu time: avg 0.937 ms, total 87516.6 ms] [avg calls per frame: 2]
14:14:51: | Convert444toNV12 - [cpu time: avg 0.93 ms, total 86861.4 ms] [avg calls per frame: 2]
14:14:51: encoder thread frame - [cpu time: avg 1.874 ms, total 87563.4 ms] [avg calls per frame: 1]
14:14:51:
14:14:51: =====Stream End: 2013-11-29, 14:14:51=================================================
14:14:52: =====Stream Start: 2013-11-29, 14:14:52===============================================
14:14:52: Multithreaded optimizations: On
14:14:52: Base resolution: 1280x720
14:14:52: Output resolution: 1280x720
14:14:52: ------------------------------------------
14:14:52: Loading up D3D10 on NVIDIA GeForce GT 650M...
14:14:52: Audio Format: 48000hz
14:14:52: Playback device Default
14:14:52: Using desktop audio input: Speakers (Cirrus Logic CS4206B (AB 40))
14:14:52: Using quad speaker setup
14:14:52: Using auxilary audio input: Microphone (Blue Snowball)
14:14:52: Using Mic QPC timestamps
14:14:52: Audio Encoding: AAC
14:14:52: bitrate: 96
14:14:52: device: Logitech HD Webcam C615,
14:14:52: device id \\?\usb#vid_046d&pid_082c&mi_02#6&52dd137&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
14:14:52: chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
14:14:52: use buffering: true - 15000000, fourCC: 'I420'
14:14:52: audio device: Disable,
14:14:52: audio device id Disabled,
14:14:52:
14:14:52: Using directshow input
14:14:53: Using bitmap image
14:14:53: ------------------------------------------
14:14:53: device: Elgato Game Capture HD,
14:14:53: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
14:14:53: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
14:14:53: use buffering: false - 0, fourCC: 'UYVY'
14:14:53:
14:14:53: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
14:14:53: Using directshow input
14:14:53: Scene buffering time set to 1500
14:14:53: Video Encoding: x264
14:14:53: fps: 30
14:14:53: width: 1280, height: 720
14:14:53: preset: veryfast
14:14:53: profile: high
14:14:53: keyint: 60
14:14:53: CBR: yes
14:14:53: CFR: no
14:14:53: max bitrate: 6000
14:14:53: buffer size: 6000
14:14:53: MMDeviceAudioSource: Frequency for device 'Speakers (Cirrus Logic CS4206B (AB 40))' is 768000, samples per sec is 48000
14:14:53: MMDeviceAudioSource: Frequency for device 'Microphone (Blue Snowball)' is 352800, samples per sec is 44100
14:14:57: Using RTMP service: Youtube
14:14:57: Server selection: rtmp://a.rtmp.youtube.com/live2
14:14:57: Interface: Broadcom 802.11n Network Adapter #2 (802.11, 290 mbps)
14:14:57: Completed handshake with rtmp://a.rtmp.youtube.com/live2 in 39 ms.
14:14:57: SO_SNDBUF was at 8192
14:14:57: SO_SNDBUF is now 65536
14:14:59: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 7744 / 780288)
14:15:00: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 0 / 780288)
14:15:04: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 524288 (buffer: 0 / 780288)
14:21:31: RTMPPublisher::SocketLoop: Stalled for 2000 ms to write 778787 bytes (buffer: 0 / 780288), unstable connection?
14:21:34: RTMPPublisher::SocketLoop: Stalled for 2836 ms to write 777753 bytes (buffer: 0 / 780288), unstable connection?
14:21:37: RTMPPublisher::SocketLoop: Stalled for 2814 ms to write 777037 bytes (buffer: 0 / 780288), unstable connection?
14:21:40: RTMPPublisher::SocketLoop: Stalled for 2821 ms to write 776548 bytes (buffer: 0 / 780288), unstable connection?
14:21:42: RTMPPublisher::SocketLoop: Stalled for 2603 ms to write 776559 bytes (buffer: 0 / 780288), unstable connection?
14:21:57: RTMPPublisher::SocketLoop: Stalled for 1710 ms to write 779037 bytes (buffer: 0 / 780288), unstable connection?
14:21:59: RTMPPublisher::SocketLoop: Stalled for 2097 ms to write 777773 bytes (buffer: 0 / 780288), unstable connection?
14:22:02: RTMPPublisher::SocketLoop: Stalled for 2780 ms to write 778403 bytes (buffer: 0 / 780288), unstable connection?
14:22:06: RTMPPublisher::SocketLoop: Stalled for 3507 ms to write 780025 bytes (buffer: 0 / 780288), unstable connection?
14:22:08: RTMPPublisher::SocketLoop: Stalled for 2300 ms to write 779975 bytes (buffer: 0 / 780288), unstable connection?
14:22:13: RTMPPublisher::SocketLoop: Stalled for 1504 ms to write 779664 bytes (buffer: 0 / 780288), unstable connection?
14:22:16: RTMPPublisher::SocketLoop: Stalled for 3304 ms to write 776373 bytes (buffer: 0 / 780288), unstable connection?
14:22:20: RTMPPublisher::SocketLoop: Stalled for 3781 ms to write 778588 bytes (buffer: 0 / 780288), unstable connection?
14:22:22: RTMPPublisher::SocketLoop: Stalled for 1975 ms to write 776302 bytes (buffer: 0 / 780288), unstable connection?
14:22:25: RTMPPublisher::SocketLoop: Stalled for 1716 ms to write 776890 bytes (buffer: 0 / 780288), unstable connection?
14:22:34: RTMPPublisher::SocketLoop: Stalled for 2388 ms to write 780201 bytes (buffer: 0 / 780288), unstable connection?
14:22:38: RTMPPublisher::SocketLoop: Stalled for 2833 ms to write 779116 bytes (buffer: 0 / 780288), unstable connection?
14:23:06: RTMPPublisher::SocketLoop: Stalled for 1641 ms to write 779703 bytes (buffer: 0 / 780288), unstable connection?
14:23:09: RTMPPublisher::SocketLoop: Stalled for 2559 ms to write 776247 bytes (buffer: 0 / 780288), unstable connection?
14:23:13: RTMPPublisher::SocketLoop: Stalled for 3637 ms to write 779523 bytes (buffer: 0 / 780288), unstable connection?
14:23:16: RTMPPublisher::SocketLoop: Stalled for 3089 ms to write 777283 bytes (buffer: 0 / 780288), unstable connection?
14:23:18: RTMPPublisher::SocketLoop: Stalled for 2748 ms to write 778311 bytes (buffer: 0 / 780288), unstable connection?
14:23:21: RTMPPublisher::SocketLoop: Stalled for 2096 ms to write 779303 bytes (buffer: 0 / 780288), unstable connection?
14:28:22: RTMPPublisher::SocketLoop: Stalled for 1969 ms to write 776353 bytes (buffer: 0 / 780288), unstable connection?
14:28:24: RTMPPublisher::SocketLoop: Stalled for 2554 ms to write 779982 bytes (buffer: 0 / 780288), unstable connection?
14:39:32: Total frames encoded: 44323, total frames duplicated: 1892 (4.27%)
14:39:32: Number of frames skipped due to encoder lag: 19 (0.04%)
14:39:32: Total frames rendered: 44272, number of late frames: 47 (0.11%) (it's okay for some frames to be late)
14:39:32: RTMPPublisher::SocketLoop: Graceful loop exit
14:39:32: Average send payload: 11906 bytes, average send interval: 16 ms
14:39:32: Number of times waited to send: 44, Waited for a total of 172927 bytes
14:39:32: Number of b-frames dropped: 313 (0.71%), Number of p-frames dropped: 934 (2.1%), Total 1247 (2.8%)
14:39:32: Number of bytes sent: 1095458587
14:39:36:
14:39:36: Profiler time results:
14:39:36:
14:39:36: ==============================================================
14:39:36: video thread frame - [100%] [avg time: 6.149 ms] [children: 69.5%] [unaccounted: 30.5%]
14:39:36: | scene->Preprocess - [61.4%] [avg time: 3.774 ms]
14:39:36: | GPU download and conversion - [8.08%] [avg time: 0.497 ms] [children: 7.06%] [unaccounted: 1.02%]
14:39:36: | | flush - [5.3%] [avg time: 0.326 ms]
14:39:36: | | CopyResource - [1.63%] [avg time: 0.1 ms]
14:39:36: | | conversion to 4:2:0 - [0.13%] [avg time: 0.008 ms]
14:39:36: Convert444Threads - [100%] [avg time: 1.011 ms] [children: 98.6%] [unaccounted: 1.38%]
14:39:36: | Convert444toNV12 - [98.6%] [avg time: 0.997 ms]
14:39:36: encoder thread frame - [100%] [avg time: 2.792 ms]
14:39:36:
14:39:36:
14:39:36: Profiler CPU results:
14:39:36:
14:39:36: video thread frame - [cpu time: avg 4.306 ms, total 190649 ms] [avg calls per frame: 1]
14:39:36: | scene->Preprocess - [cpu time: avg 2.878 ms, total 127437 ms] [avg calls per frame: 1]
14:39:36: | GPU download and conversion - [cpu time: avg 0.176 ms, total 7815.66 ms] [avg calls per frame: 1]
14:39:36: | | flush - [cpu time: avg 0.107 ms, total 4742.44 ms] [avg calls per frame: 1]
14:39:36: | | CopyResource - [cpu time: avg 0.027 ms, total 1216.82 ms] [avg calls per frame: 1]
14:39:36: | | conversion to 4:2:0 - [cpu time: avg 0.005 ms, total 234.003 ms] [avg calls per frame: 1]
14:39:36: Convert444Threads - [cpu time: avg 0.956 ms, total 84599.3 ms] [avg calls per frame: 2]
14:39:36: | Convert444toNV12 - [cpu time: avg 0.947 ms, total 83803.7 ms] [avg calls per frame: 2]
14:39:36: encoder thread frame - [cpu time: avg 1.949 ms, total 86331 ms] [avg calls per frame: 1]
14:39:36:
14:39:36: =====Stream End: 2013-11-29, 14:39:36=================================================
14:39:38: Memory Leaks Were Detected.
14:39:38:
