Question / Help Streaming problem between OBS> Twitch
Shyniii
Hello,
I explain my worries.
For over a year I stream on the streaming platform "TWITCH" with a software named "OBS".
In recent weeks, when I run my streaming program to stream on Twitch, I upload my connection makes yoyo and I can not send a correct flow. But my connection is more than adequate for streaming, 720p, 1500 biterate (50Mb Download and 5MB upload).
That's what I tried:
- Speed Test -> Stable connection which has not changed (down 50/5 Up)
- Program Change -> With Xsplit is the same, lost images, lag etc.
- Streaming platform change -> Tested "hitbox" and there miracle everything works.
- Reboot box -> Nothing changed
- PC Cleaning -> Nothing changed
- Call the provider -> It see chut upload, but it does not come from home.
- Change cable box / internet -> Nothing changed
In short, basically I really do not know of or could be the problem.
Because OBS -> Twitch, it kidding, but OBS -> Hitbox, it works. So we can say that the problem is not PC, or my connection.
Also note that this problem has come overnight, it takes place at any time of day or night, and this problem has disappeared for almost 4-5 days, and returned alone.
If you have other ideas, which could come to the problem I am listening.
Thank you in advance.
Hello,
your problem is between you, your ISP and the twitch ingest server you are sending to, but more than likely at twitch's end. post a tweet to twitch's twitter page about the issue and let them know your ISP and what ingest server you are using.
You did the right thing by trying Hitbox, because right away, that will tell you weather the issue is at your end or Twitch's end. There are countless threads on here of people complaining of similar issues, when its simply a problem between their ISP and Twitch's ingest servers. A problem that has existed for a long time. All you can do is report it to Twitch, and then try a different ingest server.
Hello,
Well it reassures me to see I 'm not the only one with problems.
I pointed to Twitch , without ever having to answer ( email + twitter ) .
Currently , everything is back . It's party, as had arrived without explanation. Hope it continue.
