Canadianakin
I have been playing around with my stream to try to improve the quality, however I do nothing seems to work.
Here is my build:
CPU: AMD FX-8150 @ 4.7Ghz
GPU: AMD R9 390 (Slight overclock)
Ram: 8Gb DDR3
OS: Windows 10
Bandwidth: 150/30 Mbps
Here is my encoding settings:
Video Encoding: x264
filter: Lanczos (best detail, 36 samples)
fps: 30
width: 1280, height: 720
preset: faster
profile: main
keyint: 60
CBR: yes
CFR: yes
max bitrate: 3500
buffer size: 3500
Here is an example of my stream quality: http://www.twitch.tv/canadianakin/v/16233067
As you can see, the interface looks grainy (see the shotgun icon), and quick movements look blurry/pixelated. This was using window capture as game capture wasn't working for me. Is there something I am doing wrong? I thought that these were fairly default settings aside from my CPU preset which had the same problems at veryfast. I was also under the assumption that my rig could handle 1080p streaming but after having the same problems I tried downscaling to 720p. Are AMD CPUs so bad for streaming that a pretty highly overclocked one still won't suffice or have I royally screwed up somewhere? Any help is appreciated.
Here is my log for that stream attached as well as on pastebin: http://pastebin.com/qVF0QWP3
Here is my build:
Ram: 8Gb DDR3
OS: Windows 10
fps: 30
preset: faster
profile: main
keyint: 60
CBR: yes
CFR: yes
max bitrate: 3500
buffer size: 3500
