Stream is very choppy! Changing settings does not help! Log File included.
adastra
Hello, so I am trying to help my friend with his stream but I have not found any fixes to his issue. His streams are not smooth, its constantly choppy, and he is using the NVENC new encoder with a 3090. Any help would be appreciated!
Correction: I do believe he was using his cpu as the encoder in this log file. However, he gets the same results when he uses his GPU.
  • 2021-06-07_14-35-13.txt
