Question / Help Stream in Low Quality and localy record in Higher Quality ?
Zou
Hi,
here is the situation I often encounter :
When I have to stream (essentially in HD), I try to get the best quality depending on the connexion quality. But when the upload bandwidth is really limited (like 1 Mega), I have to resize and decrease the bit-rate. So the quality is really poor and it's normal I have no choice but this implies that the local record will also be poor.
Is there a solution to stream with specified settings and recording locally with Higher Quality ?
If not, is it possible to consider this as a new feature? Or is it technically impossible?
Re: Stream in Low Quality but localy recording in High Quali
Log? I have no log, it's a general question about a feature (or not).
This is not currently possible without multiple copies of OBS.
Re: Stream in Low Quality and localy record in Higher Qualit
But different copies of OBS cannot access simultaneously to the same capture card, no?
Correct, only one application can access a directshow device at one time. So I suppose you're out of luck for now.
The rewrite of OBS will support recording at multiple bit rates.
