GogglesTheFox
Hi guys,
When I open up OBS and run Stream Engine, my LGP is found no problem. The problem comes though when I try to change the resolution of the Video that is being shown. Normally, I can change Resolution to any of the presets in Stream Engine. But currently, it is always reset to 720x480. It makes no difference if I change connectors (used both HMDI and Component and got the same problem) and I can change the Frame Rate, Video Bitrate, Audio Bitrate and Volume no problem.
I upgraded everything just to make sure there wasn't a problem there. As well as uninstalled and reinstalled everything. This has never happened before and the software was working fine 2 weeks ago. Can anyone help me out?
