Hi guys. Here are my specs. The description of the issue is below as well.
i5-3570k
8.0GB DDR3 667Mhz
MSI GTX 760 Twin Frozr
R7000 Nighthawk router stock firmware
Motorola Surfboard 6141 modem
100/10 connection with TWC located in NY, NY
Streaming from one out of 3 monitors. Native resolution is 1920x1200. OBS set to take 1920x1080 and finally downscaled to 1280x720
For some reason, my stream will never load. While sharing my link with a few friends, they say that the stream will not load for them. It used to work here and there but would never actually stream the video without issues. It would work for some and not load for others. At the current moment, it does not load for anyone I give my twitch link to.
By the end of a 2 hour live stream, the stream still does not load. I have zero dropped frames by the end as well. I am quite confused as to why it would not load then. Is twitch just not giving me the bandwidth to load? Or is TWC restricting me (again.... nothing is dropped.... so that doesn't make sense for me). I've tried various bitrates of 3k - 7.5k and still no dropped frames so I'm sure my connection can handle it. I will attach a log of my previous stream and a few pictures of my obs settings as well.
Any help would be greatly appreciated. Thanks!
i5-3570k
8.0GB DDR3 667Mhz
