Bug Report Sound still doesn't work on your capture device? Read here
Status
Not open for further replies.
S0N0S
Re: Sound still doesn't work on your capture device? Read h
AVerMedia Live Gamer HD (C985) here. No audio from 3.5mm jack. Unable to use HDMI in my setup, so I haven't tried that out.
Device: AVerMedia HD Capture C985 Bus 4
  Pin: Virtual Video Out
    category: {494B594A-026C-48A3-9A-8A-EC-C3-5C-FE-33-20}
    00.) major type: MEDIATYPE_Stream
         sub type: {C5C928BE-6F6D-42B6-B6-E0-43-B5-62-D9-73-C1}
         format type: FORMAT_None
  Pin: Capture
    category: PIN_CATEGORY_CAPTURE
    00.) major type: MEDIATYPE_Video
         sub type: {32315659-F072-40CA-82-9D-47-D5-D2-83-54-22}
         format type: FORMAT_VideoInfo
    01.) major type: MEDIATYPE_Video
         sub type: {56555951-0000-0010-80-00-00-AA-00-38-9B-71}
    02.) major type: MEDIATYPE_Video
    03.) major type: MEDIATYPE_Video
    04.) major type: MEDIATYPE_Video
    05.) major type: MEDIATYPE_Video
    06.) major type: MEDIATYPE_Video
    07.) major type: MEDIATYPE_Video
    08.) major type: MEDIATYPE_Video
    09.) major type: MEDIATYPE_Video
    10.) major type: MEDIATYPE_Video
    11.) major type: MEDIATYPE_Video
    12.) major type: MEDIATYPE_Video
    13.) major type: MEDIATYPE_Video
    14.) major type: MEDIATYPE_Video
    15.) major type: MEDIATYPE_Video
    16.) major type: MEDIATYPE_Video
    17.) major type: MEDIATYPE_Video
    18.) major type: MEDIATYPE_Video
    19.) major type: MEDIATYPE_Video
    20.) major type: MEDIATYPE_Video
    21.) major type: MEDIATYPE_Video
    22.) major type: MEDIATYPE_Video
    23.) major type: MEDIATYPE_Video
    24.) major type: MEDIATYPE_Video
    25.) major type: MEDIATYPE_Video
    26.) major type: MEDIATYPE_Video
    27.) major type: MEDIATYPE_Video
    28.) major type: MEDIATYPE_Video
    29.) major type: MEDIATYPE_Video
    30.) major type: MEDIATYPE_Video
    31.) major type: MEDIATYPE_Video
    32.) major type: MEDIATYPE_Video
    33.) major type: MEDIATYPE_Video
  Pin: VBI
    category: PIN_CATEGORY_VBI
  Pin: PCM Out
    00.) major type: MEDIATYPE_Audio
         sub type: MEDIASUBTYPE_PCM
         format type: FORMAT_WaveFormatEx
KeiroStarr
Jim said:
For some reason these devices aren't reporting back any audio pins, what on earth is going on?
NO idea why. Virtual Audio Cable picks them up though. If we could somehow get the data from that, you could use it to implement their audio directly through OBS.
xPaRaPhOiAx
I use a Black Magic Intensity: Shuttle, no audio is captured using OBS.
Device: Logitech Webcam C210
  Pin: Capture
         sub type: MEDIASUBTYPE_RGB24
         sub type: MEDIASUBTYPE_I420
  Pin: Still
    category: PIN_CATEGORY_STILL
Device: Decklink Video Capture
  Pin: Capture
         sub type: MEDIASUBTYPE_UYVY
         sub type: {43594448-0000-0010-80-00-00-AA-00-38-9B-71}
         sub type: {30313276-0000-0010-80-00-00-AA-00-38-9B-71}
  Pin: ~VANC
         sub type: {00000000-0000-0000-00-00-00-00-00-00-00-00}
         format type: {00000000-0000-0000-00-00-00-00-00-00-00-00}
  Pin: ~Timecode
    category: PIN_CATEGORY_TIMECODE
    00.) major type: {0482DEE3-7817-11CF-8A-03-00-AA-00-6E-CB-65}
    01.) major type: {73747874-0000-0010-80-00-00-AA-00-38-9B-71}
Lain
Forum Admin
Lain
Forum Moderator
Developer
If you use the 3.5mm jack just plug it into your sound card instead and try to pick it up that way in the mean time. God I hate directshow.
Ouren
Device: AV/C Tape Recorder/Player
  Pin: DV Vid Out
         sub type: MEDIASUBTYPE_dvsd
  Pin: DV A/V Out
    00.) major type: MEDIATYPE_Interleaved
         format type: FORMAT_DvInfo
Device: Integrated Webcam
  Pin: Capture
         sub type: MEDIASUBTYPE_YUY2
         format type: FORMAT_VideoInfo2
         sub type: MEDIASUBTYPE_MJPG
    34.) major type: MEDIATYPE_Video
    35.) major type: MEDIATYPE_Video
    36.) major type: MEDIATYPE_Video
    37.) major type: MEDIATYPE_Video
    38.) major type: MEDIATYPE_Video
    39.) major type: MEDIATYPE_Video
    40.) major type: MEDIATYPE_Video
    41.) major type: MEDIATYPE_Video
    42.) major type: MEDIATYPE_Video
    43.) major type: MEDIATYPE_Video
Canopus ADVC 110
Lain
Forum Admin
Lain
Forum Moderator
Developer
wow, a dvsd device, never thought I'd see one of those.
Saiphas_Cain
I have a feeling this won't help exactly. I noticed that OB doesn't show up on my volume mixer like everything else does. It's able to acknowledge that there is audio, I see the volumes flickering, but I don't think the system is handing it an audio connection so I doubt the cabling solution will help. This kind of sucks because OBS is by far the easiest stream recording software, with the highest clarity I've come across in my weeks of searching!
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: AMD Phenom(tm) II X4 965 Processor
CPU Speed: 3400MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 3, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
monitor 1: pos={0, 0}, size={1280, 720}
monitor 2: pos={1280, 0}, size={1280, 720}
Aero is Disabled
Adapter 1
Video Adapter: ATI Radeon HD 5500 Series
Video Adapter Dedicated Video Memory: 1061138432
Video Adapter Shared System Memory: 3207593984
Base resolution: 1280x720
Output resolution: 1280x720
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (Realtek High Definition Audio)
Using auxilary audio input: Stereo Mix (Realtek High Definition Audio)
Audio Encoding: MP3
bitrate: 128
Using graphics capture
x264: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT
x264: profile High, level 3.1
Video Encoding: x264
fps: 24
width: 1280, height: 720
preset: fast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 10
SharedTexCapture hooked
Total frames rendered: 187, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1 Avg QP:18.19 size: 84836
x264: frame P:52 Avg QP:30.55 size: 8335
x264: frame B:81 Avg QP:32.53 size: 748
x264: consecutive B-frames: 1.5% 51.9% 2.2% 44.4%
x264: mb I I16..4: 7.2% 56.2% 36.6%
x264: mb P I16..4: 0.2% 1.9% 0.4% P16..4: 30.8% 4.4% 3.0% 0.0% 0.0% skip:59.2%
x264: mb B I16..4: 0.3% 0.3% 0.0% B16..8: 7.0% 0.8% 0.0% direct: 1.2% skip:90.4% L0:28.9% L1:68.7% BI: 2.5%
x264: 8x8 transform intra:63.7% inter:68.9%
x264: coded y,uvDC,uvAC intra: 71.9% 55.6% 24.1% inter: 5.3% 3.9% 0.3%
x264: i16 v,h,dc,p: 24% 39% 22% 15%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 7% 18% 31% 5% 9% 5% 11% 4% 9%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 30% 18% 5% 7% 5% 7% 4% 6%
x264: i8c dc,h,v,p: 62% 22% 13% 3%
x264: Weighted P-Frames: Y:1.9% UV:0.0%
x264: ref P L0: 78.7% 21.3%
x264: ref B L0: 85.2% 14.8%
x264: ref B L1: 100.0% 0.0%
x264: kb/s:829.33
Profiler results:
frame - [100%] [avg time: 6.594 ms] [avg calls per frame: 1] [children: 90.4%] [unaccounted: 9.61%]
| scene->Preprocess - [0.121%] [avg time: 0.008 ms] [avg calls per frame: 1]
| video encoding and uploading - [90.3%] [avg time: 5.952 ms] [avg calls per frame: 1] [children: 38.7%] [unaccounted: 51.6%]
| | CopyResource - [0.212%] [avg time: 0.014 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.106%] [avg time: 0.007 ms] [avg calls per frame: 0]
| | call to encoder - [38.3%] [avg time: 2.523 ms] [avg calls per frame: 0]
| | sending stuff out - [0.121%] [avg time: 0.008 ms] [avg calls per frame: 0]
Warchamp7
Forum Admin
That's from Xsplit's virtual camera output (It can act as a virtual webcam), not Xsplit itself.
Saiphas_Cain
hmmmm... OK. I've not seen a program with audio not show up on the mixer before but I certainly didn't code it so I'll try the cable thing and report back.
Thanks for the info!
pedrolian
Device: Roxio GAMECAP Capture
  Pin: Capture
eNakiruh
This Audio issue is plaguing me!
Any update on when a fix will come out?
Also, Do you still need more information?
Lain
Forum Admin
Lain
Forum Moderator
Developer
Just wanted to let everyone know, paibox has implemented a potential solution to the audio problem, but I have yet to make a full test build with the new code yet.
AndehX
My Intensity Shuttle seems to have audio now, but its very choppy and intermittent. Is this something that you're looking into Jim?
Lain
Forum Admin
Lain
Forum Moderator
Developer
I may have to buy one or something to see what's going on.
AndehX
ah I see. Expensive way to fix a bug lol. Although, you can always buy one, fix whatever bugs it has, and then sell it on
eNakiruh
If this fixes the issue
I'll have unprotected sex with you
Status
