Dear User! I wanted to make a couple of videos on Youtube! Mainly Minecraft, But the problem is that my recordings either lag or they don't look like they are not good enough Quality! I want to know both my Streaming and Recording settings! If so that would be great!
Log: LOG FILE
Specs on my Alienware Laptop:
The Specs are I7-7700hq (2.8 ghz) - 4 cores!
GTX 1070
The exact laptop is https://play3r.net/reviews/laptopsnotebooks/alienware-15-r3-gaming-laptop-review-i7-7700hq-gtx-1070/
Ive been using Nvech new
SPEEDTEST SETTINGS:
Download: 238.83 MPBS
Upload: 24.16 MBPS
Currently My streaming settings are (Planing to stream onto Youtube!)
RATE CONTROL:CBR
BITRATE: 8000
KEYFRAME INTERVAL: 0
PRESET: MAX QUALITY
PROFILE: HIGH
LOOK AHEAD- OFF
PROFILE: HIGH
PSYCHO VISUAL TUNING: OFF
GPU 0
MAX B FRAMES: 4
_________________________________________________________________________________
RECORDING SETTINGS
RECORDING FORMAT: MKV
Encoder: NVIDIA NVENC H.264 NEW
RATE CONTROL: CQP
CQ LEVEL: 12
KEYFRAME INVTERVAL: 2
PRESET: MAX QUALITY
PROFILE HIGH
LOOK AHEAD OFF
PSYCHO VISUAL TUNING OFF
GPU 0
MAX B-frames- 2
PLEASE HELP ME OPTIMIZE THESE SETTINGS I AM SO CONFUSED!!!!
Log: LOG FILE
GTX 1070
SPEEDTEST SETTINGS:
Upload: 24.16 MBPS
RATE CONTROL:CBR
BITRATE: 8000
PRESET: MAX QUALITY
PROFILE: HIGH
LOOK AHEAD- OFF
PROFILE: HIGH
GPU 0
MAX B FRAMES: 4
RECORDING SETTINGS
RATE CONTROL: CQP
CQ LEVEL: 12
PRESET: MAX QUALITY
PROFILE HIGH
LOOK AHEAD OFF
GPU 0
MAX B-frames- 2
