Hello,
I've been using OBS for a good number of weeks now without any trouble, but recently, I've started having a major echo issue seemingly out of nowhere. It is not because I have a tab of my stream open in the background on the same computer that i'm streaming from - i'm watching it back on my separate laptop, and it's very distinct there. Both my game audio as well as my voice audio, and even alerts such as follower alert audio, is all echoed, from the moment I begin streaming to the second I end it.
I've been searching for an answer for a couple of hours, and haven't had any luck or found a post listing the exact problem that I have. I've tried analyzing my current log, but the only thing it mentions is that i'm streaming from a wireless connection, which is 'ok'. But that doesn't address my audio issue. I've also tried deleting and re-adding all of my sources and scenes, with no luck, as well as completely re-installing OBS from the beginning (deleting all third-party content and prior custom settings along with it) but the echo problem is still there.
This makes me think the issue is some sort of audio setting directly on my machine, unrelated to OBS? Any insight would be incredibly helpful, as I stream multiple times a week, and haven't been able to now for quite some time.
Thank you for your time reading this.
P.S. This problem began after I messed around trying to get a donation alert set up for my stream, with the help of the program Subalert and StreamTip. I don't recall changing any audio settings during this process, and even after removing the changes I made from this, the issue wasn't fixed.
