Question / Help Resolution problem ?
Awaces
Hello,
I tried to setup my OBS but unfortunally I have some problems with the screen recording.
For some reason OBS doesn't show the bottom of my screen (task bar)
THis is what's captured :
and this is what should be captured :
Is it because i'm using 2 monitors ( one 21' and one 22')
When you have your problem solved make sure to specify what it was for other users if they do a search looking for an answer to the same problem.
The problem was that DPI is enabled, and DPI messes with the capture. The solution is to (copy & paste) try right-clicking on your OBS shortcut, go to the Compatibility tab, and check "Disable display scaling on high DPI settings", restart OBS, and see if that helps.
Or just disable DPI for your displays in your windows display settings. (Setting scaling to 100% rather than above)
