pollyzoid
First bug is that the replay buffer doesn't seem to limit its length according to what I've set in the settings.
Even with a length of 300 seconds (5 minutes), OBS kept a buffer way longer than that. The first buffer was 1h 44min long, second try about 8 minutes. Trying to stop the 1h buffer resulted in OBS using over 4GB of memory and not responding in over a minute (force closed after that), no file saved. 8 minute file saved successfully.
Logs:
1h 44min buffer and force close
8min buffer and save
Second bug is that the 'Save Replay Buffer' hotkey doesn't work. Every other hotkey works, even with the same key set. I've used 'Record from Replay Buffer' and then 'Stop Recording' to get the same effect, but it would be nice if the actual hotkey worked.
Trying to use 'Save' results in identical logs as not using it.
Windows 8.1, 64-bit
Open Broadcaster Software v0.638b - 64bit
Gigabyte GTX 970
Logs:
Windows 8.1, 64-bit
Gigabyte GTX 970
