red square problem
Hi, I have a problem with my obs when I add my video capture device, the image seems to go out of screen. I can't move it and adjust it, I just see a red square in the top left corner. I delete and add again, but nothing changes
The link is to show the picture of my problem.
Anyway, it's probably a zero-size frame because it's not getting any data. Once it gets something, it should expand to the actual size, relative to the canvas, and then you can work with it.
If nothing comes from the capture card, OBS doesn't know what size it is, so it starts with no size at all. Once it receives something, *then* it works like you expect.
This only happens the first time you add each thing. Once it's working and set the way you want it, it'll remember that.
I understand better, thank you for taking the time to answer my problem.
Do you have any advice on how to remove it?
