Question / Help Red Screening when using AVerMedia LGP Stream Engine.
Ave
So i've been scouring the internet trying to find an answer to this and nothing is working for me.
I am trying to stream gameplay of my Wii U on Twitch using LGP Stream Engine and OBS, the solutions that have been suggested to me are:
One - Closing both Skype and Google Chrome and then restart my computer, fixing resolution to match in both programs, then running OBS.
Two - Running 32-bit OBS and making sure that under Video Capture Device, the option it gives me says LGP Stream Engine, where instead it shows AVerMedia C875 Capture under every circumstance I try.
Three: Updating my Drivers and all software, which has been done, I have even tried using older versions of OBS and am getting the same issue.
Therefore I am lead to the conclusion that it is OBS that is having the issue picking up my Capture Card, could anyone please help me if they had the same issue?
Alternatively, and i'm not sure whether or not this has anything to do with it, when I start my OBS a popup window show up with "Failed to initialize plugin plugins/OBSApi.dll", and I am not sure how to fix this as I have uninstalled/installed OBS multiple times and currently cannot find the file.
Thank you for any help!
