PTZ Camera Control Over USB using UVC Protocol? MacOS BigSur
JamRatt
Just like the topic says...
I have two Rocware RC20 PTZ cameras that I would love to control via OBS using something like PTZoptics Control plugin.
However, the cameras have USB and 8-pin RS-232 (round) ports — no Ethernet. I can find no reference that they have IP addresses, so PTZoptics freebies seem to be out of the realm. FYI, the IR remote on these is EXACTLY the same as PTZoptics. But I tried PTZoptics IR remote shortcut for showing the IP address (*+#+4), no dice, probably proprietary.
The specs say the cameras can be fully controlled via UVC. While OBS displays the cameras, it does not seem to recognize even basic UVC such as brightness, etc. But, I am unsure if I fully understand UVC capabilities, as I usually did video tweaks via filters.
It's not the end of the world if I can't control the cameras via software, as I plan to use position/zoom presets. But to not have to grab a remote, press the corresponding camera button, and then press the preset or manually pan, tilt, zoom... would be nice.
Additionally, I have considered finding a way to assign an IP address to a local USB, striking out. And have considered faking far-end control but, that seems like a fail point waiting to happen.
On PTZOptics's call today (on their YouTube channel), there was a specific question about USB / UVC, and the answer was (one of) their free software PTZ controller apps vs their hardware joystick controllers would be the right tool to use
Felgercarb! Thank you, Lawrence_SoCal. I watched the YouTube vid from today. I had ignored their stand-alone Camera Control app, assuming it was a desktop replica of what is in the OBS plugin.
However, the Multi Cameras Settings under the standalone and plugin are totally different. [See attached images.]
I need to play with it more, but the PTZoptics software sees the cams under USB and I am able to control the PTZ.
This mostly works. But I can't get the presets to work. Still noodling with this but if anyone has suggestions. Ah, the holes I dig to meet a budget. L
We also tested PTZOptics app on 1 of our cheap usb ptz camera, the presets just move to the home position. While the mac version app has the left and right direction reversed.
