Hello all,
I have a question/problem:
About my setup:
Camera: Panasonic Lumix GH4
Capture card: Blackmagic Intensity Pro
PC: i5 and GTX960
Unfortunately the capture card in my PC works only sporadically.
Sometimes it recognizes the camera and sometimes not. I have also tried the card by friends. Sometimes it works wonderfully and sometimes not at all. If the card does not recognize the camera and you open the properties of the card in OBS, everything hangs until you leave the properties again. I have also tried to set all PCI versions manually on my computer, unfortunately still the same behavior.
So I turn to the forum do you have any experience with the BM Intensity Pro in combination with OBS?
Thanks
About my setup:
PC: i5 and GTX960
Thanks
