Question / Help problem with stream through video card
UAIUmka
Hello, I faced such a problem that the obs does not broadcast with the codec H.264.The current version of the video driver is installed. In the log, I do not pick it up. I will be grateful for the help
My laptop:
Intel core i5-8250u
nvidea mx150
8gb ram
Windows 10pro 64bit
log:
09:55:44.939: CPU Name: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
09:55:44.939: CPU Speed: 1800MHz
09:55:44.939: Physical Cores: 4, Logical Cores: 8
09:55:44.939: Physical Memory: 8066MB Total, 3680MB Free
09:55:44.939: Windows Version: 10.0 Build 17763 (revision: 379; 64-bit)
09:55:44.939: Running as administrator: false
09:55:44.939: Aero is Enabled (Aero is always on for windows 8 and above)
09:55:44.939: Windows 10 Gaming Features:
09:55:44.939: Game Bar: Off
09:55:44.939: Game DVR: Off
09:55:44.939: Game DVR Background Recording: Off
09:55:44.939: Game Mode: Off
09:55:44.941: Sec. Software Status:
09:55:44.942:
09:55:44.942:
09:55:44.942:
09:55:44.942: Current Date/Time: 2019-03-28, 09:55:44
09:55:44.942: Browser Hardware Acceleration: true
09:55:44.942: Portable mode: false
09:55:45.257: OBS 23.0.2 (64-bit, windows)
09:55:45.257: ---------------------------------
09:55:45.258: audio settings reset:
09:55:45.258: samples per sec: 44100
09:55:45.258: speakers: 2
09:55:45.266: ---------------------------------
09:55:45.267: Initializing D3D11...
09:55:45.267: Available Video Adapters:
09:55:45.273: Adapter 1: NVIDIA GeForce MX150
09:55:45.273: Dedicated VRAM: 2080038912
09:55:45.273: Shared VRAM: 4229285888
09:55:45.273: output 1: pos={0, 0}, size={1920, 1080}, attached=true
09:55:45.273: Adapter 2: Intel(R) UHD Graphics 620
09:55:45.273: Dedicated VRAM: 134217728
09:55:45.279: Loading up D3D11 on adapter NVIDIA GeForce MX150 (0)
09:55:45.335: D3D11 loaded successfully, feature level used: 45056
09:55:46.040: ---------------------------------
09:55:46.040: video settings reset:
09:55:46.040: base resolution: 1920x1080
09:55:46.040: output resolution: 1920x1080
09:55:46.040: downscale filter: Bilinear
09:55:46.040: fps: 30/1
09:55:46.040: format: NV12
09:55:46.040: YUV mode: 601/Partial
09:55:46.041: NV12 texture support enabled
09:55:46.043: Audio monitoring device:
09:55:46.043: name: По умолчанию
09:55:46.043: id: default
09:55:46.043: ---------------------------------
09:55:46.098: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
09:55:46.100: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
09:55:46.158: [AMF] AMF Test failed due to one or more errors.
09:55:46.158: Failed to initialize module 'enc-amf.dll'
09:55:46.261: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
09:55:46.298: [obs-browser]: Version 2.3.0
09:55:46.478: Couldn't find VLC installation, VLC video source disabled
09:55:46.494: No blackmagic support
09:55:46.554: ---------------------------------
09:55:46.554: Loaded Modules:
09:55:46.554: win-wasapi.dll
09:55:46.554: win-mf.dll
09:55:46.554: win-ivcam.dll
09:55:46.554: win-dshow.dll
09:55:46.554: win-decklink.dll
09:55:46.554: win-capture.dll
09:55:46.554: vlc-video.dll
09:55:46.554: text-freetype2.dll
09:55:46.554: rtmp-services.dll
09:55:46.554: obs-x264.dll
09:55:46.554: obs-vst.dll
09:55:46.554: obs-transitions.dll
09:55:46.554: obs-text.dll
09:55:46.554: obs-qsv11.dll
09:55:46.554: obs-outputs.dll
09:55:46.554: obs-filters.dll
09:55:46.554: obs-ffmpeg.dll
09:55:46.554: obs-browser.dll
09:55:46.554: image-source.dll
09:55:46.554: frontend-tools.dll
09:55:46.554: enc-amf.dll
09:55:46.554: decklink-ouput-ui.dll
09:55:46.554: coreaudio-encoder.dll
09:55:46.554: ==== Startup complete ===============================================
09:55:46.557: All scene data cleared
09:55:46.557: ------------------------------------------------
09:55:46.659: WASAPI: Device 'Динамики (Realtek High Definition Audio)' initialized
09:55:46.782: WASAPI: Device 'Микрофон (Realtek High Definition Audio)' initialized
09:55:46.782: Switched to scene 'Сцена'
09:55:46.782: ------------------------------------------------
09:55:46.782: Loaded scenes:
09:55:46.782: - scene 'Сцена':
09:55:46.826: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Mic/Aux)
09:55:46.826:
09:56:11.230: Settings changed (stream 1)
09:56:11.230: ------------------------------------------------
09:56:27.729: [qsv encoder: 'streaming_h264'] settings:
09:56:27.729: rate_control: CBR
09:56:27.729: target_bitrate: 5000
09:56:27.729: fps_num: 30
09:56:27.729: fps_den: 1
09:56:27.729: width: 1920
09:56:27.729: height: 1080
09:56:27.730: [qsv encoder: 'streaming_h264'] debug info:
09:56:27.735: impl: D3D11
09:56:27.735: surf: D3D11
09:56:27.798: m_nSurfNum: 12
09:56:27.808: [qsv encoder: 'msdk_impl'] Undefined behavior (MFX_ERR_UNDEFINED_BEHAVIOR)
09:56:27.811: [qsv encoder: 'streaming_h264'] qsv failed to load
09:56:27.811: major: 1
09:56:27.811: minor: 27
09:56:27.811: Stream output type 'rtmp_output' failed to start!
