Question / Help Problem with resolution
Martin Skalicky
Hello guys,
I start with this: My monitor have resolution 1680:1050. I'm playing CS:GO on resolution 1280:1024(4:3). But when im trying to record CS:GO by any mode, in video i have black places and CS: GO is only small pard of the screen, or There is only part of CS:GO.
Here are images: http://imgur.com/a/CZyNp
Thank you for any help.
Hey, Martin
Have you tried using the edit scene option? If you click preview stream first, then click on edit scene, you should be able to move around the csgo screen capture.
In order to have the game fit within the screen the way you want it you'll have to drag it into a corner, until the red outline snaps to one side or corner, then stretch the entire thing from the opposite corner until it snaps into place.
If you can still see black bars or blank space where csgo should be, you may have to go to the properties of the csgo game capture and set it to ignore aspect ratio or so. I would post pictures but I'm not on my computer right now.
Hopefully this will help you out though.
Thank you, problem will be in CS GO, because if i play it on my monitor, it will adapt and its "fullscreen" without black sides, so i will solve this problem by changing resolution by CS GO.
