19:16:42: Open Broadcaster Software v0.625b - 32bit (´・ω・`)
19:16:42: -------------------------------
19:16:42: CPU Name: Intel(R) Pentium(R) CPU G645 @ 2.90GHz
19:16:42: CPU Speed: 2893MHz
19:16:42: Physical Memory: 4049MB Total, 2744MB Free
19:16:42: stepping id: 7, model 42, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 2, total cores 2
19:16:42: monitor 1: pos={0, 0}, size={1280, 1024}
19:16:42: Windows Version: 6.2 Build 9200
19:16:42: Aero is Enabled
19:16:42: OBS Modules:
19:16:42: Base Address Module
19:16:42: 00AE0000 OBS.exe
19:16:42: 6E8B0000 OBSApi.dll
19:16:42: 6E3D0000 DShowPlugin.dll
19:16:42: 6E870000 GraphicsCapture.dll
19:16:42: 6E3A0000 NoiseGate.dll
19:16:42: 6E380000 PSVPlugin.dll
19:16:42: 6E180000 WebSocketAPIPlugin.dll
19:16:42: ------------------------------------------
19:16:42: Adapter 1
19:16:42: Video Adapter: NVIDIA GeForce GT 630
19:16:42: Video Adapter Dedicated Video Memory: 2091446272
19:16:42: Video Adapter Shared System Memory: 1854435328
19:16:42: Video Adapter Output 1: pos={0, 0}, size={1280, 1024}, attached=true
19:16:42: =====Stream Start: 2014-07-28, 19:16:42===============================================
19:16:42: Multithreaded optimizations: On
19:16:42: Base resolution: 640x480
19:16:42: Output resolution: 640x480
19:16:42: Loading up D3D10 on NVIDIA GeForce GT 630 (Adapter 1)...
19:16:42: Audio Format: 44100 Hz
19:16:42: Audio Channels: 2 Ch
19:16:42: Playback device Default
19:16:42: Using desktop audio input: Speakers / Headphones (IDT High Definition Audio CODEC)
19:16:42: Global Audio time adjust: 0
19:16:42: Using auxilary audio input: Rear Mic (IDT High Definition Audio CODEC)
19:16:42: Mic time offset: 0
19:16:42: Audio Encoding: AAC
19:16:42: bitrate: 96
19:16:42: Using text output
19:16:43: Using Monitor Capture
19:16:43: Scene buffering time set to 700
19:16:43: ------------------------------------------
19:16:43: Video Encoding: x264
19:16:43: fps: 30
19:16:43: width: 640, height: 480
19:16:43: preset: veryfast
19:16:43: profile: main
19:16:43: keyint: 60
19:16:43: CBR: yes
19:16:43: CFR: no
19:16:43: max bitrate: 403
19:16:43: buffer size: 403
19:16:49: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
19:16:50: Completed handshake with rtmp://publish.livestream.com/mogulus/7ouhou0nline/username=7ouhou0nline/password=g3ns0ky0fr4nc3/isAutoLive=true in 841 ms.
19:16:51: SO_SNDBUF was at 65536
19:17:12: RTMPPublisher::SocketLoop: Stalled for 1599 ms to write 102782 bytes (buffer: 0 / 131072), unstable connection?
19:17:25: RTMPPublisher::SocketLoop: Stalled for 1865 ms to write 115367 bytes (buffer: 0 / 131072), unstable connection?
19:17:28: RTMPPublisher::SocketLoop: Stalled for 2628 ms to write 128759 bytes (buffer: 0 / 131072), unstable connection?
19:17:30: RTMPPublisher::SocketLoop: Stalled for 1881 ms to write 123530 bytes (buffer: 0 / 131072), unstable connection?
19:17:33: RTMPPublisher::SocketLoop: Stalled for 1957 ms to write 130752 bytes (buffer: 0 / 131072), unstable connection?
19:17:39: RTMPPublisher::SocketLoop: Stalled for 1509 ms to write 96767 bytes (buffer: 0 / 131072), unstable connection?
19:17:42: RTMPPublisher::SocketLoop: Stalled for 1865 ms to write 101123 bytes (buffer: 0 / 131072), unstable connection?
19:17:44: RTMPPublisher::SocketLoop: Stalled for 1608 ms to write 99912 bytes (buffer: 0 / 131072), unstable connection?
19:18:03: RTMPPublisher::SocketLoop: Stalled for 2074 ms to write 130997 bytes (buffer: 0 / 131072), unstable connection?
19:18:10: RTMPPublisher::SocketLoop: Stalled for 1527 ms to write 108283 bytes (buffer: 0 / 131072), unstable connection?
19:18:14: RTMPPublisher::SocketLoop: Stalled for 3580 ms to write 130926 bytes (buffer: 0 / 131072), unstable connection?
19:18:16: RTMPPublisher::SocketLoop: Stalled for 1837 ms to write 88643 bytes (buffer: 0 / 131072), unstable connection?
19:18:18: Total frames encoded: 2836, total frames duplicated: 1 (0.04%)
19:18:18: Total frames rendered: 2856, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
19:18:21: RTMPPublisher::SocketLoop: Stalled for 1766 ms to write 111428 bytes (buffer: 0 / 131072), unstable connection?
19:18:23: RTMPPublisher::SocketLoop: Stalled for 1885 ms to write 120952 bytes (buffer: 0 / 131072), unstable connection?
19:18:25: RTMPPublisher::SocketLoop: Graceful loop exit
19:18:27: Average send payload: 10064 bytes, average send interval: 161 ms
19:18:27: Number of times waited to send: 6, Waited for a total of 9346 bytes
19:18:27: Number of b-frames dropped: 39 (1.4%), Number of p-frames dropped: 34 (1.2%), Total 73 (2.6%)
19:18:27: Number of bytes sent: 5847229
19:18:27:
19:18:27: Profiler time results:
19:18:27:
19:18:27: ==============================================================
19:18:27: video thread frame - [100%] [avg time: 1.115 ms] [children: 52.6%] [unaccounted: 47.4%]
19:18:27: | scene->Preprocess - [20.8%] [avg time: 0.232 ms]
19:18:27: | GPU download and conversion - [31.8%] [avg time: 0.355 ms] [children: 18.3%] [unaccounted: 13.5%]
19:18:27: | | flush - [14.8%] [avg time: 0.165 ms]
19:18:27: | | CopyResource - [3.05%] [avg time: 0.034 ms]
19:18:27: | | conversion to 4:2:0 - [0.448%] [avg time: 0.005 ms]
19:18:27: Convert444Thread - [100%] [avg time: 0.404 ms] [children: 97.5%] [unaccounted: 2.48%]
19:18:27: | Convert444toNV12 - [97.5%] [avg time: 0.394 ms]
19:18:27: encoder thread frame - [100%] [avg time: 0.576 ms] [children: 8.16%] [unaccounted: 91.8%]
19:18:27: | sending stuff out - [8.16%] [avg time: 0.047 ms]
19:18:27:
19:18:27:
19:18:27: Profiler CPU results:
19:18:27:
19:18:27: video thread frame - [cpu time: avg 0.284 ms, total 812.5 ms] [avg calls per frame: 1]
19:18:27: | scene->Preprocess - [cpu time: avg 0.005 ms, total 15.625 ms] [avg calls per frame: 1]
19:18:27: | GPU download and conversion - [cpu time: avg 0.136 ms, total 390.625 ms] [avg calls per frame: 1]
19:18:27: | | flush - [cpu time: avg 0.082 ms, total 234.375 ms] [avg calls per frame: 1]
19:18:27: | | CopyResource - [cpu time: avg 0.027 ms, total 78.125 ms] [avg calls per frame: 1]
19:18:27: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:18:27: Convert444Thread - [cpu time: avg 0.441 ms, total 1250 ms] [avg calls per frame: 1]
19:18:27: | Convert444toNV12 - [cpu time: avg 0.441 ms, total 1250 ms] [avg calls per frame: 1]
19:18:27: encoder thread frame - [cpu time: avg 0.016 ms, total 46.875 ms] [avg calls per frame: 1]
19:18:27: | sending stuff out - [cpu time: avg 0.005 ms, total 15.625 ms] [avg calls per frame: 1]
19:18:27:
19:18:27: =====Stream End: 2014-07-28, 19:18:27=================================================
19:23:01: No Intel graphics adapter visible in QSVHelper.exe, Optimus problem?
19:23:01: CUDA loaded successfully
19:23:01: 1 CUDA capable devices found
19:23:01: [ GPU #0 - < GeForce GT 630 > has Compute SM 2.1, NVENC Not Available ]
19:23:01: No NVENC capable devices found
