Satsujin Kou
After I updated my graphic driver to latest version this problem occur.. however it only happened when I use OBS, HEVC still working if I use Radeon ReLive. Oh and it didn't happen when I use the previous graphic driver and obviously I don't want to rollback my driver only to fix this problem. So I wonder, is this a problem with the driver or the obs? cuz I know Radeon is famous with their broken drivers
Here's the screenshot of the said problem, and a detail about my graphic card
Thanks in advance :)
#Edit: added Log File
#Edit 2: Just realized I posted in the wrong room, I use OBS Studio not OBS Classic.. Sorry
16:08:32.291: ==== Recording Start ===============================================
16:08:32.291: [ffmpeg muxer: 'adv_file_output'] Writing file 'D:/Recording/2017-08-01 16-08-32.mp4'...
16:08:32.369: [AMF] <Id: 31> Initial Frame Latency is 60007600 nanoseconds.
16:09:55.026: [ffmpeg muxer: 'adv_file_output'] Output of file 'D:/Recording/2017-08-01 16-08-32.mp4' stopped
16:09:55.026: Output 'adv_file_output': stopping
16:09:55.026: Output 'adv_file_output': Total encoded frames: 4964
16:09:55.026: Output 'adv_file_output': Total drawn frames: 4964
16:09:55.027: ==== Recording Stop ================================================
16:09:55.791: [game-capture: 'Game Capture'] ------------------ gl capture freed ------------------
16:09:55.810: [game-capture: 'Game Capture'] gl shared texture capture successful
16:09:55.812: [game-capture: 'Game Capture'] shared texture capture successful
16:10:14.599: Settings changed (outputs)
16:10:14.599: ------------------------------------------------
16:12:17.443: [AMF] [H265]<Id: 40> Encoder Parameters:
16:12:17.443: [AMF] [H265]<Id: 40> Backend:
16:12:17.443: [AMF] [H265]<Id: 40> Video API: Direct3D 11
16:12:17.443: [AMF] [H265]<Id: 40> Video Adapter: Radeon(TM) RX 460 Graphics (VEN_1002/DEV_67ef/SUB_a4601787/REV_00cf)
16:12:17.443: [AMF] [H265]<Id: 40> OpenCL: Not Supported
16:12:17.443: [AMF] [H265]<Id: 40> Transfer: Disabled
16:12:17.443: [AMF] [H265]<Id: 40> Conversion: Disabled
16:12:17.443: [AMF] [H265]<Id: 40> Multi-Threading: Disabled
16:12:17.443: [AMF] [H265]<Id: 40> Queue Size: 4
16:12:17.443: [AMF] [H265]<Id: 40> Frame:
16:12:17.443: [AMF] [H265]<Id: 40> Format: NV12 601 Partial
16:12:17.443: [AMF] [H265]<Id: 40> Resolution: 1920x1080
16:12:17.443: [AMF] [H265]<Id: 40> Frame Rate: 60/1
16:12:17.443: [AMF] [H265]<Id: 40> Aspect Ratio: 1:1
16:12:17.443: [AMF] [H265]<Id: 40> Static:
16:12:17.443: [AMF] [H265]<Id: 40> Usage: Transcoding
16:12:17.443: [AMF] [H265]<Id: 40> Quality Preset: Balanced
16:12:17.443: [AMF] [H265]<Id: 40> Profile: Main 4.1
16:12:17.443: [AMF] [H265]<Id: 40> Tier: Main
16:12:17.443: [AMF] [H265]<Id: 40> Coding Type: Automatic
16:12:17.443: [AMF] [H265]<Id: 40> Max. Reference Frames: 1
16:12:17.443: [AMF] [H265]<Id: 40> Max. Long-Term Reference Frames: 0
16:12:17.443: [AMF] [H265]<Id: 40> Rate Control:
16:12:17.443: [AMF] [H265]<Id: 40> Method: Peak Constrained Variable Bitrate
16:12:17.443: [AMF] [H265]<Id: 40> Pre-Pass Mode: Disabled
16:12:17.443: [AMF] [H265]<Id: 40> QP:
16:12:17.443: [AMF] [H265]<Id: 40> Ranges:
16:12:17.443: [AMF] [H265]<Id: 40> I-Frame: 18 - 51
16:12:17.443: [AMF] [H265]<Id: 40> P-Frame: 18 - 51
16:12:17.443: [AMF] [H265]<Id: 40> Fixed:
16:12:17.443: [AMF] [H265]<Id: 40> I-Frame: 26
16:12:17.443: [AMF] [H265]<Id: 40> P-Frame: 26
16:12:17.443: [AMF] [H265]<Id: 40> Bitrate:
16:12:17.443: [AMF] [H265]<Id: 40> Target: 18500000 bit/s
16:12:17.443: [AMF] [H265]<Id: 40> Peak: 30000000 bit/s
16:12:17.443: [AMF] [H265]<Id: 40> Flags:
16:12:17.443: [AMF] [H265]<Id: 40> Filler Data: Enabled
16:12:17.443: [AMF] [H265]<Id: 40> Frame Skipping: Disabled
16:12:17.443: [AMF] [H265]<Id: 40> Period: 0 Frames
16:12:17.443: [AMF] [H265]<Id: 40> Behaviour: Skip every Nth frame
16:12:17.443: [AMF] [H265]<Id: 40> Variance Based Adaptive Quantization: Enabled
16:12:17.443: [AMF] [H265]<Id: 40> Enforce Hypothetical Reference Decoder: Disabled
16:12:17.443: [AMF] [H265]<Id: 40> Video Buffering Verfier:
16:12:17.443: [AMF] [H265]<Id: 40> Buffer Size: 20000000 bits
16:12:17.443: [AMF] [H265]<Id: 40> Initial Fullness: 100 %
16:12:17.443: [AMF] [H265]<Id: 40> Max. Access Unit Size: 0
16:12:17.443: [AMF] [H265]<Id: 40> Picture Control:
16:12:17.443: [AMF] [H265]<Id: 40> IDR: 0 GOPs
16:12:17.443: [AMF] [H265]<Id: 40> I: 0 Frames
16:12:17.443: [AMF] [H265]<Id: 40> P: 0 Frames
16:12:17.443: [AMF] [H265]<Id: 40> B: 0 Frames
16:12:17.443: [AMF] [H265]<Id: 40> GOP:
16:12:17.443: [AMF] [H265]<Id: 40> Type: Fixed
16:12:17.443: [AMF] [H265]<Id: 40> Size: 0
16:12:17.443: [AMF] [H265]<Id: 40> Size Range: 0 - 16
16:12:17.443: [AMF] [H265]<Id: 40> Alignment: Enabled
16:12:17.443: [AMF] [H265]<Id: 40> Deblocking Filter: Disabled
16:12:17.443: [AMF] [H265]<Id: 40> Motion Estimation: Quarter, Half
16:12:17.443: [AMF] [H265]<Id: 40> Intra-Refresh:
16:12:17.464: [AMF] <Id: 40> <Plugin::AMD::EncoderH265::GetIntraRefreshMode> Failed to retrieve value, error AMF_INVALID_ARG (code 4)
16:12:45.128: Settings changed (outputs)
16:12:45.128: ------------------------------------------------
