Question / Help Problem recording gameplay
Pablillo11
Hello everyone.
I have a problem that I'm sure you can solve. Normally I usually stream with OBS and it usually works fine. The problem is how much I try to record, I think I have the CBR rate (10,000).
The gameplays are recorded wonderfully, the problem is that the file weighs very little (2.5 gb - 30 minutes) and it's recorded at 60 constant FPS and at 1080p.
When I open the video, it is very difficult to go from scenes, perhaps to pass with the mouse from minute 1 to minute 10 is left thinking the computer and it takes a few seconds to change.
I also have another problem is that I want to edit and render it, I use Adobe Premier to do it when loading the file takes a long time to load the sequence, just as I do the same in the timeline when I want to scroll in different video points.
Has it happened to you? It is normal? Do I have something wrong in the configuration or I'm missing a Plug-In?
Thank you very much!
