cloakedalien
Just as the topic suggest. I've had this weird screen tearing issue since I upgraded to Windows 11 (on launch day so that would've been October 2021). I kinda just assumed it was Windows and forcing v.sync through NVidia control panel gave me massive issues with frame rendering times, etc. It affects the entire preview area so not specific to a source.
By downloading the ZIP archives of various versions I narrowed it down to OBS-Studio-27.1-rc2 working as expected and OBS-Studio-27.1-rc3 having the screen tearing issue which matches well with the date I upgraded to Windows 11. I've experienced this issue over all different versions of OBS, Windows 11 updates and Nvidia drivers since. Administrator mode or not does not make a difference.
Interestingly this coincides with the tweak "Added performance fixes for Windows 11 and Windows 10 Insider builds", but that's merely an observation on my part.
Specs:
64-bit OBS
Ryzen 9 3900X
Nvidia RTX 3080 (511.79)
4k@60hz screen (LG UM7100PLB, 3840x2160, HDR disabled in Windows Display Settings)
Windows 11 Pro (21H2)
I have not yet been able to verify if the problem exists in Windows 10 with the same setup for obvious reasons. I tried changing the resolution to 1080p on the 4K screen and the problem persisted. However on my secondary 1080p monitor it was a lot harder to notice. This problem is restricted to OBS preview and is not present in rc2 and earlier so shouldn't be the display specifically although it could be a part in the puzzle.
I'm aware that this might be a an extreme edge case if not easily reproducible, unfortunately I play through the preview so it's an uncomfortable edge but I'd be happy to do more tests and provide more info!
Here are a couple of camera captures that at least manages to capture the tearing in a "barebone" scene setup (video+audio capture only). It's much more obvious IRL.
https://www.youtube.com/watch?v=dMvPyxP8Uwo (rc3 showing tearing)
https://www.youtube.com/watch?v=JjQbyoBPAMk (rc2 showing lack of tearing)
Logfiles:
Specs:
64-bit OBS
Ryzen 9 3900X
Logfiles:
