How to select power point window capture? I’ve already grant permission for OBS screen recording but it doesn’t show up.. The only option that I had is to choose display capture & record the entire window..
You should try to check in the window capture option there is a checkbox for showing null/empty names, it sometimes appears there. Once you check it, it will show on the dropdown menu way more options to record and one of then should be powerpoint.
