Question / Help Possible to record with two instances AND two different AUDIO sources?
Tim K
Hi:
I have no problem running two instances of OBS and recording two different streams. However, the problem is I need to record audio from each of these sources. Is there any way to tell OBS to record audio each of the relative sources, rather than just ALL windows sound?
Basically, I don't think this is possible ... I think what OBS needs is a mixer (like the Windows mixer) where you can adjust and mute individual apps sound.
The only work-around I can see is if you ran audio of the second stream you wanted to record out of another computer to the mic in on the computer running the two instances, and choosing MIC for the second instance's input. Might not that work ok?
Thanks,
Tim
