OBS will not record or stream and idk wut to look for or fix
Bella Lugosi
Hi I have searched on here for a good 30 min, and can't find something specific enough to help with my issue (i'm sure its here but just hoping a thread can help.
So I will provide as much as i can and if im missing any info needed plz lmk
I attached a screenshot and log too if that helps, and when i hit start streaming or start recording it just says "Failed to start [rec]" and then something about NVENC or AMD encoders and to check the log
so any help yall can share, i would greatly appreciate it !
Device name
Processor Intel(R) Core(TM) i5-3340M CPU @ 2.70GHz 2.70 GHz
Installed RAM 8.00 GB (7.87 GB usable)
Device ID
Product ID
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 10 Home
Version 22H2
Installed on ‎
OS build
Experience Windows Feature Experience Pack
  • 2024-05-20 14-09-12.txt
About your issue with the "Starting the output failed" issue in connection with the Quicksync hardware encoder: your 11 year old CPU is too old. Its hardware encoder isn't supported any more by OBS. Use x264 as encoder instead or get a PC with a recent CPU.
About your network issue ("14:13:17.020: Output 'test_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 707 (90.9%)" in your log": see https://obsproject.com/kb/stream-connection-troubleshooting
tyvm
I am having trouble finding how to or where to download or use your recommendation of x264 as an encoder, could you share with me where I could find the info or how to on making this change? tyvm for ur time and input
