OBS Studio using too much VRAM?
Kivy
Hello, I cant find any info on this issue so I'm hoping someone here can help.
Here's a screenshot of my task manager. As you can see my VRAM was almost 100% during the stream, and then I ended the stream, closed OBS, and my VRAM went down by half. The game was still running. I'm also attaching a log which shows nothing wrong. Is it normal for OBS to use 3GB of VRAM? or am I doing something wrong here? I'd like to avoid having to buy a 16GB graphics card when my game barely uses 4GB anyways.
Update: I formatted and did a fresh re-install of Windows 11, never even installed the AMD Adrenalin software, and OBS is still using 4GB of Vram...
I cant even stream Oblivion Remaster because the game was made to use 8GB of Vram but with OBS using an extra 3GB, my game just crashes.
Here's a 4h stream I did today on a fresh OBS install:
This is a screenshot of task manager right after i ended the stream, showing a dip of 2-3GB in vram usage:
I get that I'm running 5 encodes at the same time but using up that much vram just to encode video sounds like a performance issue imo, especially with how nvidia and amd are still selling brand new gpus with only 8gb of vram, and that's not even enough to run some of the newer games - without streaming them.
You always can run single source test recording without multi-resolution to see how much resources it consumes. Each source/filter and each encoder in OBS consumes some resources. Higher resolution -> more resources needed, and so on.
I think the issue is Browser Source Acceleration. It seems to be saving every frame of my overlays into VRAM, but not clearing them later? I have a twitch chat overlay to add chat over the video so there's lots going on, and with browser source acceleration it seems to be using about a gigabyte of vram per hour of stream. Disabling acceleration "fixes" that issue but really that's more of a band-aid solution.
Maybe just run the cpu in x264 mode instead of using the gpus, so you don't have to share the gpus with your games!
Try to completely reinstall the drivers using DDU and install only the driver or the minimum version. The problem may be in the software from AMD.
i have the same exact issue, anything being displayed adds massively to the VRAM consumption, climbing as high as 20+ gb used by OBS on my 5090. Only happens with browser source hardware acceleration turned on. Lumia hudfx, nutty's spotify widget etc, anything on screen causes consumption to keep going up and never releases it
