Lots of issues, right from the very start.
19:23:10.028: ================================
19:23:10.029: Warning: OBS is already running!
19:23:10.029: ================================
It gets worse, you need to close all apps not being used. System is thin, no RAM left to play....
19:23:10.077: Physical Memory: 15881MB Total,
245MB Free
Rendering lag is GPU overload & there's plenty of it.
21:28:02.497: Output 'simple_file_output': Number of lagged frames due to rendering lag/stalls: 2227 (1.5%)
Update your iGPU driver.
19:23:11.604: Driver Version: 32.0.101.7026
Intel® Core™ Ultra 5 Processor 125U (12M Cache, up to 4.30 GHz) - Download supporting resources inclusive drivers, software, bios, and firmware updates.
www.intel.com
Disable this, run Defender.
19:23:10.158: Sentinel Agent: enabled (AV)
Run OBS @ 30 or 60FPS. I would get another monitor to capture from, 1080p. In the meantime, you may want to downscale to 1080p.
19:23:13.360: video settings reset:
19:23:13.360: base resolution: 1920x1200
19:23:13.360: output resolution: 1920x1200
19:23:13.360: downscale filter: Bicubic
19:23:13.360: fps: 20/1
There's more but run a test after all that is done a see if things improve.
OBS Knowledge Base. Learn best practices to solve encoding performance issues
obsproject.com
