Question / Help OBS Stops streaming and Starting again
ilikechickendog
Hi Guys When I have been Streaming tonight It stopped casting and start again I have tried adding Hotkeys Lowering Bitrate and Resetting the internet but none of these work is there another way I can use if this happens again here are the logs from tonight https://gist.github.com/45234344336e234aef71 https://gist.github.com/7b2ad8ae25d1108ac042 https://gist.github.com/e08aa7d3ad9063ba5e07 https://gist.github.com/2e025dd5aad0054425fe https://gist.github.com/b8bd07ff232aded119a6 https://gist.github.com/b8bd07ff232aded119a6 hope this helps
Use this tool for your region:
http://www.teamliquid.net/forum/tech-support/478845-twitchtest-twitch-bandwidth-tester
post a screenshot of the results.
EDIT: also you shouldn't stream over wireless. this will cause many many issues for you.
