Question / Help OBS picks up sound but no video, new problem.
Cant seem to upload file so I will post half of the log twice in 2 replies
16:39:01: Open Broadcaster Software v0.651b - 32bit (´・ω・`)
16:39:01: -------------------------------
16:39:01: CPU Name: AMD FX(tm)-6300 Six-Core Processor
16:39:01: CPU Speed: 3793MHz
16:39:01: Physical Memory: 4095MB Total, 1982MB Free
16:39:01: stepping id: 0, model 2, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 6, total cores 3
16:39:01: monitor 1: pos={0, 0}, size={1920, 1080}
16:39:01: Windows Version: 6.2 Build 9200
16:39:01: Aero is Enabled
16:39:01: OBS Modules:
16:39:01: Base Address Module
16:39:01: 009C0000 OBS.exe
16:39:01: 0F210000 OBSApi.dll
16:39:01: 5A5F0000 DShowPlugin.dll
16:39:01: 50020000 GraphicsCapture.dll
16:39:01: 77740000 NoiseGate.dll
16:39:01: 6F180000 PSVPlugin.dll
16:39:01: 609E0000 scenesw.dll
16:39:01: ------------------------------------------
16:39:01: Adapter 1
16:39:01: Video Adapter: NVIDIA GeForce GTX 660
16:39:01: Video Adapter Dedicated Video Memory: 2086273024
16:39:01: Video Adapter Shared System Memory: 2147807232
16:39:01: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
16:39:01: =====Stream Start: 2015-06-26, 16:39:01===============================================
16:39:01: Multithreaded optimizations: On
16:39:01: Base resolution: 1920x1080
16:39:01: Output resolution: 1280x720
16:39:01: Loading up D3D10 on NVIDIA GeForce GTX 660 (Adapter 1)...
16:39:01: Audio Format: 48000 Hz
16:39:01: Audio Channels: 2 Ch
16:39:01: Playback device {0.0.0.00000000}.{74e9d3e2-fd7c-4db0-aee2-a39ffa39b846}
16:39:01: Using desktop audio input: Speakers (TRITTON KUNAI STEREO HEADSET)
16:39:01: Global Audio time adjust: 0
16:39:01: Using auxilary audio input: Microphone (TRITTON KUNAI STEREO HEADSET)
16:39:01: Mic time offset: 0
16:39:01: Audio Encoding: AAC
16:39:01: bitrate: 128
16:39:01: Using graphics capture
16:39:01: Scene buffering time set to 700
16:39:01: Video Encoding: x264
16:39:01: fps: 40
16:39:01: width: 1280, height: 720
16:39:01: preset: veryfast
16:39:01: profile: main
16:39:01: keyint: 80
16:39:01: CBR: yes
16:39:01: CFR: yes
16:39:01: max bitrate: 1000
16:39:01: buffer size: 1000
16:39:02: Audio timestamp for device 'Microphone (TRITTON KUNAI STEREO HEADSET)' was behind target timestamp by 152128426
16:39:03: Using RTMP service: Twitch
16:39:03: Server selection: rtmp://live-mia.twitch.tv/app
16:39:03: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
16:39:03: Completed handshake with rtmp://live-mia.twitch.tv/app in 710 ms.
16:39:04: SO_SNDBUF was at 65536
16:39:10: FlushBufferedVideo: Flushing 8 packets over 175 ms
16:39:10: Total frames encoded: 318, total frames duplicated: 3 (0.94%)
16:39:10: Total frames rendered: 343, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
16:39:10: ~RTMPPublisher: Packet flush completed in 99 ms
16:39:10: ~RTMPPublisher: Send thread terminated in 16 ms
16:39:10: RTMPPublisher::SocketLoop: Graceful loop exit
16:39:10: ~RTMPPublisher: Socket thread terminated in 0 ms
16:39:10:
16:39:10: Profiler time results:
16:39:10:
16:39:10: ==============================================================
16:39:10: video thread frame - [100%] [avg time: 1.376 ms] [children: 11%] [unaccounted: 89%]
16:39:10: | scene->Preprocess - [0.145%] [avg time: 0.002 ms]
16:39:10: | GPU download and conversion - [10.8%] [avg time: 0.149 ms] [children: 10%] [unaccounted: 0.799%]
16:39:10: | | flush - [9.45%] [avg time: 0.13 ms]
16:39:10: | | CopyResource - [0.436%] [avg time: 0.006 ms]
16:39:10: | | conversion to 4:2:0 - [0.145%] [avg time: 0.002 ms]
16:39:10: Convert444Thread - [100%] [avg time: 0.915 ms] [children: 99.2%] [unaccounted: 0.765%]
16:39:10: | Convert444toNV12 - [99.2%] [avg time: 0.908 ms]
16:39:10: encoder thread frame - [100%] [avg time: 1.389 ms] [children: 2.02%] [unaccounted: 98%]
16:39:10: | sending stuff out - [2.02%] [avg time: 0.028 ms]
16:39:10:
16:39:10:
16:39:10: Profiler CPU results:
16:39:10:
16:39:10: video thread frame - [cpu time: avg 0.865 ms, total 296.875 ms] [avg calls per frame: 1]
16:39:10: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:39:10: | GPU download and conversion - [cpu time: avg 0.045 ms, total 15.625 ms] [avg calls per frame: 1]
16:39:10: | | flush - [cpu time: avg 0.045 ms, total 15.625 ms] [avg calls per frame: 1]
16:39:10: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:39:10: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:39:10: Convert444Thread - [cpu time: avg 0.904 ms, total 281.25 ms] [avg calls per frame: 1]
16:39:10: | Convert444toNV12 - [cpu time: avg 0.904 ms, total 281.25 ms] [avg calls per frame: 1]
16:39:10: encoder thread frame - [cpu time: avg 2.116 ms, total 656.25 ms] [avg calls per frame: 1]
16:39:10: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:39:10:
16:39:10: =====Stream End: 2015-06-26, 16:39:10=================================================
16:39:40: ~RTMPublisher: Received error 10060 while waiting for graceful shutdown.
16:39:40: ~RTMPPublisher: Final socket shutdown completed in 30001 ms
16:39:40: Average send payload: 3046 bytes, average send interval: 21 ms
16:39:40: Number of times waited to send: 0, Waited for a total of 0 bytes
16:39:40: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:39:40: Number of bytes sent: 737230
16:39:41: =====Stream Start: 2015-06-26, 16:39:41===============================================
16:39:41: Multithreaded optimizations: On
16:39:41: Base resolution: 1920x1080
16:39:41: Output resolution: 1280x720
16:39:41: ------------------------------------------
16:39:41: Loading up D3D10 on NVIDIA GeForce GTX 660 (Adapter 1)...
16:39:41: Audio Format: 48000 Hz
16:39:41: Audio Channels: 2 Ch
16:39:41: Playback device {0.0.0.00000000}.{74e9d3e2-fd7c-4db0-aee2-a39ffa39b846}
16:39:41: Using desktop audio input: Speakers (TRITTON KUNAI STEREO HEADSET)
16:39:41: Global Audio time adjust: 0
16:39:41: Using auxilary audio input: Microphone (TRITTON KUNAI STEREO HEADSET)
16:39:41: Mic time offset: 0
16:39:41: Audio Encoding: AAC
16:39:41: bitrate: 128
16:39:41: Using graphics capture
16:39:41: Trying to hook process: arma3.exe
Warning -- GraphicsCaptureSource::AttemptCapture: Failed to inject library, GetLastError = 5
16:39:41: Scene buffering time set to 700
16:39:41: Video Encoding: x264
16:39:41: fps: 40
16:39:41: width: 1280, height: 720
16:39:41: preset: veryfast
16:39:41: profile: main
16:39:41: keyint: 80
16:39:41: CBR: yes
16:39:41: CFR: yes
16:39:41: max bitrate: 1000
16:39:41: buffer size: 1000
16:39:42: Audio timestamp for device 'Microphone (TRITTON KUNAI STEREO HEADSET)' was behind target timestamp by 152168606
16:39:43: Using RTMP service: Twitch
16:39:43: Server selection: rtmp://live-mia.twitch.tv/app
16:39:43: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
16:39:43: Completed handshake with rtmp://live-mia.twitch.tv/app in 383 ms.
16:39:44: SO_SNDBUF was at 65536
16:39:56: FlushBufferedVideo: Flushing 8 packets over 175 ms
16:39:56: Total frames encoded: 573, total frames duplicated: 3 (0.52%)
16:39:56: Total frames rendered: 599, number of late frames: 2 (0.33%) (it's okay for some frames to be late)
16:39:56:
16:39:56: Profiler time results:
16:39:56:
16:39:56: ==============================================================
16:39:56: video thread frame - [100%] [avg time: 1.179 ms] [children: 14.8%] [unaccounted: 85.2%]
16:39:56: | scene->Preprocess - [0.17%] [avg time: 0.002 ms]
16:39:56: | GPU download and conversion - [14.7%] [avg time: 0.173 ms] [children: 13.6%] [unaccounted: 1.1%]
16:39:56: | | flush - [12.5%] [avg time: 0.147 ms]
16:39:56: | | CopyResource - [0.763%] [avg time: 0.009 ms]
16:39:56: | | conversion to 4:2:0 - [0.339%] [avg time: 0.004 ms]
16:39:56: Convert444Thread - [100%] [avg time: 0.963 ms] [children: 99.2%] [unaccounted: 0.831%]
16:39:56: | Convert444toNV12 - [99.2%] [avg time: 0.955 ms]
16:39:56: encoder thread frame - [100%] [avg time: 1.511 ms] [children: 3.24%] [unaccounted: 96.8%]
16:39:56: | sending stuff out - [3.24%] [avg time: 0.049 ms]
16:39:56:
16:39:56:
16:39:56: Profiler CPU results:
16:39:56:
16:39:56: video thread frame - [cpu time: avg 1.173 ms, total 703.125 ms] [avg calls per frame: 1]
16:39:56: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:39:56: | GPU download and conversion - [cpu time: avg 0.13 ms, total 78.125 ms] [avg calls per frame: 1]
16:39:56: | | flush - [cpu time: avg 0.13 ms, total 78.125 ms] [avg calls per frame: 1]
16:39:56: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:39:56: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:39:56: Convert444Thread - [cpu time: avg 1.739 ms, total 984.375 ms] [avg calls per frame: 1]
16:39:56: | Convert444toNV12 - [cpu time: avg 1.739 ms, total 984.375 ms] [avg calls per frame: 1]
16:39:56: encoder thread frame - [cpu time: avg 1.769 ms, total 1000 ms] [avg calls per frame: 1]
16:39:56: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:39:56:
16:39:56: =====Stream End: 2015-06-26, 16:39:56=================================================
16:39:56: ~RTMPPublisher: Packet flush completed in 105 ms
16:39:56: ~RTMPPublisher: Send thread terminated in 1 ms
16:39:56: RTMPPublisher::SocketLoop: Graceful loop exit
16:39:56: ~RTMPPublisher: Socket thread terminated in 0 ms
16:40:07: ~RTMPPublisher: Final socket shutdown completed in 10183 ms
16:40:07: Average send payload: 3276 bytes, average send interval: 22 ms
16:40:07: Number of times waited to send: 0, Waited for a total of 0 bytes
16:40:07: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:40:07: Number of bytes sent: 1670957
16:40:07: Terminating 0x21c4
16:40:07: Terminating 0x21c8
16:40:07: Terminating 0x22d8
16:40:07: Terminating 0x22dc
Last game capture log:
2015-06-24, 23:25:53: we're booting up:
23:25:53: CaptureThread: attached to process arma3launcher.exe
23:25:53: D3D9 Present
23:25:53: (half life scientist) everything.. seems to be in order
