Every time I have tried to stream it will not stay connected for more than 30 seconds. I have changed nothing in the last week between my streams. Any help would be wonderful.
18:45:31: CLR host plugin strings not found, dynamically loading 4 strings
18:45:31: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
18:45:31: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
18:45:31: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
18:45:31: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
18:45:31: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
18:45:31: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
18:45:31: CLRHost:: Could not find/load browser settings at location C:\Users\mark\AppData\Roaming\OBS\pluginData\browser.json
18:45:31: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\mark\AppData\Roaming\OBS\pluginData\browser.json'.
18:45:31: File name: 'C:\Users\mark\AppData\Roaming\OBS\pluginData\browser.json'
18:45:31: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
18:45:31: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
18:45:31: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
18:45:31: at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
18:45:31: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
18:45:43: Open Broadcaster Software v0.654b - 32bit (´・ω・`)
18:45:43: -------------------------------
18:45:43: CPU Name: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
18:45:43: CPU Speed: 3500MHz
18:45:43: Physical Memory: 4095MB Total, 3954MB Free
18:45:43: stepping id: 2, model 63, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 12, total cores 6
18:45:43: monitor 1: pos={0, 0}, size={1920, 1080}
18:45:43: monitor 2: pos={1920, 0}, size={1920, 1080}
18:45:43: monitor 3: pos={3840, 0}, size={1920, 1080}
18:45:43: Windows Version: 6.3 Build 9600 (revision 17415)
18:45:43: Aero is Enabled
18:45:43: OBS Modules:
18:45:43: Base Address Module
18:45:43: 00190000 OBS.exe
18:45:43: 5A770000 OBSApi.dll
18:45:43: 73EA0000 CLRHostPlugin.dll
18:45:43: 5F350000 DShowPlugin.dll
18:45:43: 5F250000 GraphicsCapture.dll
18:45:43: 5D1D0000 NoiseGate.dll
18:45:43: 74340000 PSVPlugin.dll
18:45:43: 73A50000 scenesw.dll
18:45:43: ------------------------------------------
18:45:43: Adapter 1
18:45:43: Video Adapter: NVIDIA GeForce GTX 970
18:45:43: Video Adapter Dedicated Video Memory: 3221225472
18:45:43: Video Adapter Shared System Memory: 1073676288
18:45:43: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
18:45:43: Video Adapter Output 2: pos={1920, 0}, size={1920, 1080}, attached=true
18:45:43: Adapter 2
18:45:43: Video Adapter Output 1: pos={3840, 0}, size={1920, 1080}, attached=true
18:45:43: =====Stream Start: 2015-08-02, 18:45:43===============================================
18:45:43: Multithreaded optimizations: On
18:45:43: Base resolution: 1920x1080
18:45:43: Output resolution: 1920x1080
18:45:43: Loading up D3D10 on NVIDIA GeForce GTX 970 (Adapter 1)...
18:45:43: Audio Format: 48000 Hz
18:45:43: Audio Channels: 2 Ch
18:45:43: Playback device Default
18:45:43: Using desktop audio input: Speakers (High Definition Audio Device)
18:45:43: Global Audio time adjust: 0
18:45:43: Using auxilary audio input: Line In (3- Scarlett 2i2 USB)
18:45:43: Mic time offset: 0
18:45:43: Audio Encoding: AAC
18:45:43: bitrate: 128
18:45:43: device: Logitech HD Webcam C310,
18:45:43: device id \\?\usb#vid_046d&pid_081b&mi_00#6&22ba3f0c&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
18:45:43: chosen type: I420, usingFourCC: false, res: 1280x960 - 1280x960, frameIntervals: 333333-2000000
18:45:43: use buffering: false - 0, fourCC: 'I420'
18:45:43: audio device: Disable,
18:45:43: audio device id Disabled,
18:45:43: audio time offset 0,
18:45:43:
18:45:43: Using directshow input
18:45:44: Using Monitor Capture
18:45:44: Scene buffering time set to 700
18:45:44: ------------------------------------------
18:45:44: Video Encoding: x264
18:45:44: fps: 30
18:45:44: width: 1920, height: 1080
18:45:44: preset: veryfast
18:45:44: profile: main
18:45:44: keyint: 60
18:45:44: CBR: yes
18:45:44: CFR: yes
18:45:44: max bitrate: 3500
18:45:44: buffer size: 3500
18:46:25: Total frames encoded: 1216, total frames duplicated: 0 (0.00%)
18:46:25: Total frames rendered: 1241, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
18:46:25:
18:46:25: Profiler time results:
18:46:25:
18:46:25: ==============================================================
18:46:25: video thread frame - [100%] [avg time: 1.372 ms] [children: 47.4%] [unaccounted: 52.6%]
18:46:25: | scene->Preprocess - [42.1%] [avg time: 0.578 ms]
18:46:25: | GPU download and conversion - [5.25%] [avg time: 0.072 ms] [children: 4.59%] [unaccounted: 0.656%]
18:46:25: | | flush - [3.86%] [avg time: 0.053 ms]
18:46:25: | | CopyResource - [0.437%] [avg time: 0.006 ms]
18:46:25: | | conversion to 4:2:0 - [0.292%] [avg time: 0.004 ms]
18:46:25: Convert444Threads - [100%] [avg time: 1.095 ms] [children: 99.5%] [unaccounted: 0.548%]
18:46:25: | Convert444toNV12 - [99.5%] [avg time: 1.089 ms]
18:46:25: encoder thread frame - [100%] [avg time: 1.706 ms] [children: 0.117%] [unaccounted: 99.9%]
18:46:25: | sending stuff out - [0.117%] [avg time: 0.002 ms]
18:46:25:
18:46:25:
18:46:25: Profiler CPU results:
18:46:25:
18:46:25: video thread frame - [cpu time: avg 0.616 ms, total 765.625 ms] [avg calls per frame: 1]
18:46:25: | scene->Preprocess - [cpu time: avg 0.176 ms, total 218.75 ms] [avg calls per frame: 1]
18:46:25: | GPU download and conversion - [cpu time: avg 0.05 ms, total 62.5 ms] [avg calls per frame: 1]
18:46:25: | | flush - [cpu time: avg 0.025 ms, total 31.25 ms] [avg calls per frame: 1]
18:46:25: | | CopyResource - [cpu time: avg 0.012 ms, total 15.625 ms] [avg calls per frame: 1]
18:46:25: | | conversion to 4:2:0 - [cpu time: avg 0.012 ms, total 15.625 ms] [avg calls per frame: 1]
18:46:25: Convert444Threads - [cpu time: avg 1.072 ms, total 5218.75 ms] [avg calls per frame: 4]
18:46:25: | Convert444toNV12 - [cpu time: avg 1.065 ms, total 5187.5 ms] [avg calls per frame: 4]
18:46:25: encoder thread frame - [cpu time: avg 1.117 ms, total 1359.38 ms] [avg calls per frame: 1]
18:46:25: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
18:46:25:
18:46:25: =====Stream End: 2015-08-02, 18:46:25=================================================
18:45:43: Adapter 1
18:45:43: Adapter 2
18:45:43:
18:45:44: fps: 30
18:45:44: CBR: yes
18:45:44: CFR: yes
18:46:25:
18:46:25:
18:46:25:
18:46:25:
18:46:25:
18:46:25:
