alexjucu72
So my video is freezing while recording and i don't know what to do for example : https://www.youtube.com/watch?v=Ds9nH3SQrDY
looks like your settings are to high and to much CPU usage with your encode. post your log fileSo my video is freezing while recording and i don't know what to do for example : https://www.youtube.com/watch?v=Ds9nH3SQrDY
Here's my log , you can specify me the right settings for obs please ?looks like your settings are to high and to much CPU usage with your encode. post your log file
Yeah i will upgrade my processor as soon as possible thank you , but any settings for me ? :(I dont mean to be negative but your PC doesnt look like it's up to the task. It's almost 9 years old and you're trying to record at 900p at 30fps
Comparing that to people with much newer PC's who are probably streaming at 720p.
I think you need an upgrade
When i'm trying to low the resolution it's working a lil bit better but idkI dont mean to be negative but your PC doesnt look like it's up to the task. It's almost 9 years old and you're trying to record at 900p at 30fps
Downscale to 600p or 450p no higher. 30fps is fine. Encoder profile on normal (not high), key frame interval at 2 (not auto) bitrate/buffer 2000 for 600p or 1500 for 450p. Turn off CFRHere's my log , you can specify me the right settings for obs please ?
