OBS crashing when running Vertical Virtual Camera for multi-streaming
dfaux
Hello! I've been searching for days now as to why OBS-Studio is crashing when I run Vertical virtual camera. I use it to multi-stream to TikTok.
Whenever I stream, I run TikTok Live Studio and OBS at the same time with TikTok LS camera is set to OBS Virtual Camera just to save some time building scenes and sources. I've ran instances where TikTok LS is running and closed and it does the same.
When Vertical virtual camera is running is set to both, it will crash. When it's set to main or vertical canvas, it won't even run at all. I've uninstalled and reinstalled vertical, I've updated and rolled back versions of OBS, NVIDIA Studio Driver and NVIDIA Game Ready Driver just to test and see which one would work but none of them resolves my issues. I've also uninstalled and reinstalled and updated plug-ins and I'm still running the same problem. Hope someone can direct me and look at the crash logs and help me figure out what's really going on here.
Thank you and have a wonderful Thanksgiving!
https://obsproject.com/logs/crashes/AXxFoQ5YiWJwKO4D
If you have issues with a third party plugin you should contact its dev via the Discussion section on the particular plugins' page or wherever the dev have set for this.
