OBS crashes when going into a camera's properties
LUCI_14
Been trying to fix this for months and so many videos and streams have been delayed because of this.
Please help!
log:
23:58:53.313: Command Line Arguments: --disable-updater --steam
23:58:53.314: CPU Name: Intel(R) Core(TM) i5-10600KF CPU @ 4.10GHz
23:58:53.314: CPU Speed: 4104MHz
23:58:53.314: Physical Cores: 6, Logical Cores: 12
23:58:53.314: Physical Memory: 16292MB Total, 6793MB Free
23:58:53.314: Windows Version: 10.0 Build 19044 (release: 2009; revision: 2130; 64-bit)
23:58:53.314: Running as administrator: false
23:58:53.314: Aero is Enabled (Aero is always on for windows 8 and above)
23:58:53.314: Windows 10/11 Gaming Features:
23:58:53.314: Game Bar: On
23:58:53.314: Game DVR: On
23:58:53.316: Game DVR Background Recording: Off
23:58:53.316: Game Mode: Probably On (no reg key set)
23:58:53.317: Sec. Software Status:
23:58:53.318: Microsoft Defender Antivirus: enabled (AV)
23:58:53.318: Windows Firewall: enabled (FW)
23:58:53.319: Current Date/Time: 2022-11-05, 23:58:53
23:58:53.319: Browser Hardware Acceleration: true
23:58:53.319: Hide OBS windows from screen capture: false
23:58:53.319: Qt Version: 6.3.1 (runtime), 6.3.1 (compiled)
23:58:53.319: Portable mode: false
23:58:53.694: OBS 28.1.2 (64-bit, windows)
23:58:53.694: ---------------------------------
23:58:53.714: ---------------------------------
23:58:53.714: audio settings reset:
23:58:53.714: samples per sec: 48000
23:58:53.714: speakers: 2
23:58:53.714: max buffering: 960 milliseconds
23:58:53.714: buffering type: dynamically increasing
23:58:53.729: ---------------------------------
23:58:53.729: Initializing D3D11...
23:58:53.729: Available Video Adapters:
23:58:53.732: Adapter 0: NVIDIA GeForce GTX 1660 SUPER
23:58:53.732: Dedicated VRAM: 1975517184
23:58:53.732: Shared VRAM: 4246962176
23:58:53.732: PCI ID: 10de:21c4
23:58:53.732: Driver Version: 31.0.15.2647
23:58:53.732: output 0:
23:58:53.732: name=VG279QR
23:58:53.732: pos={0, 0}
23:58:53.732: size={1920, 1080}
23:58:53.732: attached=true
23:58:53.732: refresh=165
23:58:53.732: space=RGB_FULL_G22_NONE_P709
23:58:53.732: sdr_white_nits=80
23:58:53.732: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
23:58:53.732: output 1:
23:58:53.732: name=SAMSUNG
23:58:53.732: pos={-1366, 390}
23:58:53.732: size={1366, 768}
23:58:53.732: refresh=60
23:58:53.733: Adapter 1: NVIDIA GeForce GTX 1660 SUPER
23:58:53.733: Dedicated VRAM: 1975517184
23:58:53.733: Shared VRAM: 4246962176
23:58:53.733: PCI ID: 10de:21c4
23:58:53.733: Driver Version: 31.0.15.2647
23:58:53.735: Loading up D3D11 on adapter NVIDIA GeForce GTX 1660 SUPER (0)
23:58:53.802: D3D11 loaded successfully, feature level used: b000
23:58:53.802: DXGI increase maximum frame latency success
23:58:53.802: D3D11 GPU priority setup failed (not admin?)
23:58:55.024: ---------------------------------
23:58:55.024: video settings reset:
23:58:55.024: base resolution: 1920x1080
23:58:55.024: output resolution: 1280x720
23:58:55.024: downscale filter: Bicubic
23:58:55.024: fps: 30/1
23:58:55.024: format: NV12
23:58:55.024: YUV mode: Rec. 709/Partial
23:58:55.024: NV12 texture support enabled
23:58:55.024: P010 texture support not available
23:58:55.026: Audio monitoring device:
23:58:55.026: name: Default
23:58:55.026: id: default
23:58:55.026: ---------------------------------
23:58:55.028: No AJA devices found, skipping loading AJA UI plugin
23:58:55.028: Failed to initialize module 'aja-output-ui.dll'
23:58:55.030: No AJA devices found, skipping loading AJA plugin
23:58:55.030: Failed to initialize module 'aja.dll'
23:58:55.030: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
23:58:55.149: [CoreAudio encoder]: Adding CoreAudio AAC encoder
23:58:55.163: Failed to load 'en-US' text for module: 'decklink-captions.dll'
23:58:55.177: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
23:58:55.194: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
23:58:55.194: Failed to initialize module 'decklink.dll'
23:58:55.247: [AMF] Unable to load 'amfrt64.dll', error code 126.
23:58:55.248: [AMF] AMF Test failed due to one or more errors.
23:58:55.248: Failed to initialize module 'enc-amf.dll'
23:58:55.298: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
23:58:55.298: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
23:58:55.298: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
23:58:55.330: [obs-browser]: Version 2.18.7
23:58:55.330: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.0.0-5060-shared-textures.2591+g4204d54+chromium-103.0.5060.134 (compiled)
23:58:55.358: NVENC supported
23:58:55.489: [NVENC] AV1 is not supported
23:58:55.503: [noise suppress]: NVIDIA RTX denoiser disabled, redistributable not found
23:58:55.504: [NVIDIA RTX VIDEO FX]: FX disabled, redistributable not found.
23:58:55.787: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.0.1 | RPC Version: 1)
23:58:55.787: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.3.1 | Qt version (run-time): 6.3.1
23:58:55.787: [obs-websocket] [obs_module_load] Linked ASIO Version: 101201
23:58:55.787: [obs-websocket] [Config::Load] (FirstLoad) Generating new server password.
23:58:55.795: [obs-websocket] [obs_module_load] Module loaded.
23:58:55.846: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
23:58:55.967: ---------------------------------
23:58:55.967: Loaded Modules:
23:58:55.967: win-wasapi.dll
23:58:55.967: win-mf.dll
23:58:55.967: win-dshow.dll
23:58:55.967: win-capture.dll
23:58:55.967: vlc-video.dll
23:58:55.967: text-freetype2.dll
23:58:55.967: rtmp-services.dll
23:58:55.967: obs-x264.dll
23:58:55.967: obs-websocket.dll
23:58:55.967: obs-vst.dll
23:58:55.967: obs-transitions.dll
23:58:55.967: obs-text.dll
23:58:55.967: obs-qsv11.dll
23:58:55.967: obs-outputs.dll
23:58:55.967: obs-filters.dll
23:58:55.967: obs-ffmpeg.dll
23:58:55.967: obs-browser.dll
23:58:55.967: image-source.dll
23:58:55.967: frontend-tools.dll
23:58:55.967: decklink-output-ui.dll
23:58:55.967: decklink-captions.dll
23:58:55.967: coreaudio-encoder.dll
23:58:55.967: ==== Startup complete ===============================================
23:58:56.025: No scene file found, creating default scene
23:58:56.062: All scene data cleared
23:58:56.062: ------------------------------------------------
23:58:56.077: [win-wasapi: 'Desktop Audio'] update settings:
23:58:56.077: device id: default
23:58:56.077: use device timing: 1
23:58:56.080: [win-wasapi: 'Mic/Aux'] update settings:
23:58:56.080: device id: default
23:58:56.080: use device timing: 0
23:58:56.080: Switched to scene 'Scene'
23:58:56.080: Failed to glob scene collections
23:58:56.098: WASAPI: Device 'Speakers (High Definition Audio Device)' [48000 Hz] initialized
23:58:56.111: WASAPI: Device 'Microphone (2- Live Gamer MINI)' [48000 Hz] initialized
23:59:07.727: User added source 'Video Capture Device' (dshow_input) to scene 'Scene'
23:59:07.740: Video Capture Device: DecodeDeviceId failed
23:59:07.740: Video Capture Device: Video configuration failed
The latest NVIDIA driver causes this, try downgrading it.
I'm having this problem as well. What driver versions have been tested or known to be stable?
I'm on 527.56 (as of NYE 2023) and it's been dying on me for the past few driver updates already...
Just worth noting that the first time I start a video stream after a computer restart (shutdown -r -t 0) works as expected, but attempting to start it again (by doing anything, be that deleting the source, changing scenes, quitting OBS, disabling/re-enabling, etc.) results in OBS crashing when going into properties. If you don't go into properties, I think it's still gracefully handling the directshow failing in some way or another just by because the source is loaded in the scene. Reproduced in both beta (29.0.0rc3) and stable (28.1.2).
Logs: https://obsproject.com/logs/DoZp93qyfS0Ccmfl
