Obs connection problems via Speedify
DanielB1979
Hi there,
I'm trying to use OBS with the app Speedify to use it's channel bonding function.
However OBS can't connect to the streaming plattform (Vimeo).
I have set "bound to IP" to standard and activated dynamic bitrate.
When I turn Speediy off it works like charm. I am aware that the issue might be with Speedify itself - but since I can get no help there I thought i might try it here...
Does anyone have the same issues?
I've been having similar issues with v28, cannot recall if I had the same problems with 27.
I am currently messing with binding OBS to the Speedify network adapter. The Speedify adapter is identified in OBS as "[Local Area Connection] 10.2.0.2
Seems to be working better for now.
