00:11:09: Open Broadcaster Software v0.571b - 32bit (´・ω・`)
00:11:09: -------------------------------
00:11:09: CPU Name: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
00:11:09: CPU Speed: 3400MHz
00:11:09: Physical Memory: 4095MB Total, 4095MB Free
00:11:09: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
00:11:09: monitor 1: pos={0, 0}, size={1920, 1080}
00:11:09: monitor 2: pos={-1920, 0}, size={1920, 1080}
00:11:09: Windows Version: 6.1 Build 7601 S
00:11:09: Aero is Enabled
00:11:09: OBS Modules:
00:11:09: Base Address Module
00:11:09: 003B0000 OBS.exe
00:11:09: 653A0000 OBSApi.dll
00:11:09: 65370000 DShowPlugin.dll
00:11:09: 65AC0000 GraphicsCapture.dll
00:11:09: 65A40000 NoiseGate.dll
00:11:09: 65980000 PSVPlugin.dll
00:11:09: ------------------------------------------
00:11:09: Adapter 1
00:11:09: Video Adapter: NVIDIA GeForce GTX 660 Ti
00:11:09: Video Adapter Dedicated Video Memory: 2051153920
00:11:09: Video Adapter Shared System Memory: 2147807232
00:11:09: =====Stream Start: 2013-10-15, 00:11:09===============================================
00:11:09: Multithreaded optimizations: On
00:11:09: Base resolution: 1920x1080
00:11:09: Output resolution: 1920x1080
00:11:09: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
00:11:09: Audio Format: 48000hz
00:11:09: Playback device Default
00:11:09: Using desktop audio input: Headset Earphone (ASTRO Wireless Transmitter )
00:11:09: Using auxilary audio input: Microphone (3- Yeti Stereo Microphone)
00:11:09: Audio Encoding: AAC
00:11:09: bitrate: 128
00:11:09: Using bitmap image
00:11:09: Using graphics capture
00:11:09: device: Logitech HD Pro Webcam C920,
00:11:09: device id \\?\usb#vid_046d&pid_082d&mi_00#7&1f4e9d9&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
00:11:09: chosen type: I420, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-2000000, fourCC: 'I420'
00:11:09: audio device: Disable,
00:11:09: audio device id Disabled,
00:11:09:
00:11:09: Using directshow input
00:11:09: Video Encoding: x264
00:11:09: fps: 30
00:11:09: width: 1920, height: 1080
00:11:09: preset: veryfast
00:11:09: profile: high
00:11:09: keyint: 60
00:11:09: CBR: yes
00:11:09: CFR: yes
00:11:09: max bitrate: 600
00:11:09: buffer size: 600
00:11:09: MMDeviceAudioSource: Frequency for device 'Headset Earphone (ASTRO Wireless Transmitter )' is 384000, samples per sec is 48000
00:11:09: MMDeviceAudioSource: Frequency for device 'Microphone (3- Yeti Stereo Microphone)' is 352800, samples per sec is 44100
00:11:09: SharedTexCapture hooked
00:11:12: Using RTMP service: Twitch / Justin.tv
00:11:12: Server selection: rtmp://live-lax.justin.tv/app
00:11:12: Interface: Belkin N+ Wireless USB Adapter (802.11, 177 mbps)
00:11:12: Completed handshake with rtmp://live-lax.justin.tv/app in 86 ms.
00:11:13: SO_SNDBUF was at 8192
00:11:13: SO_SNDBUF is now 65536
00:11:16: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 131072)
00:14:32: RTMPPublisher::SendLoop: Stalled for 2098 ms to write 130166 bytes (buffer: 0 / 131072), unstable connection?
00:20:48: Total frames encoded: 17340, total frames duplicated: 2 (0.01%)
00:20:48: Total frames rendered: 17344, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
00:20:49: RTMPPublisher::SocketLoop: Graceful loop exit
00:20:49: Average send payload: 2894 bytes, average send interval: 31 ms
00:20:49: Number of times waited to send: 2, Waited for a total of 8208 bytes
00:20:49: Number of b-frames dropped: 16 (0.093%), Number of p-frames dropped: 14 (0.081%), Total 30 (0.17%)
00:20:49: Number of bytes sent: 52699208
00:20:49:
00:20:49: Profiler time results:
00:20:49:
00:20:49: ==============================================================
00:20:49: video thread frame - [100%] [avg time: 1.419 ms] [children: 42.6%] [unaccounted: 57.4%]
00:20:49: | scene->Preprocess - [42.6%] [avg time: 0.605 ms]
00:20:49: GPU download and conversion - [100%] [avg time: 0.191 ms] [children: 79.6%] [unaccounted: 20.4%]
00:20:49: | flush - [65.4%] [avg time: 0.125 ms]
00:20:49: | CopyResource - [12.6%] [avg time: 0.024 ms]
00:20:49: | conversion to 4:2:0 - [1.57%] [avg time: 0.003 ms]
00:20:49: Convert444Threads - [100%] [avg time: 1.426 ms] [children: 99.5%] [unaccounted: 0.491%]
00:20:49: | Convert444toNV12 - [99.5%] [avg time: 1.419 ms]
00:20:49: encoder thread frame - [100%] [avg time: 1.738 ms]
00:20:49:
00:20:49:
00:20:49: Profiler CPU results:
00:20:49:
00:20:49: video thread frame - [cpu time: avg 0.882 ms, total 15303.7 ms] [avg calls per frame: 1]
00:20:49: | scene->Preprocess - [cpu time: avg 0.49 ms, total 8502.05 ms] [avg calls per frame: 1]
00:20:49: GPU download and conversion - [cpu time: avg 0.077 ms, total 1341.61 ms] [avg calls per frame: 1]
00:20:49: | flush - [cpu time: avg 0.031 ms, total 546.004 ms] [avg calls per frame: 1]
00:20:49: | CopyResource - [cpu time: avg 0.025 ms, total 436.8 ms] [avg calls per frame: 1]
00:20:49: | conversion to 4:2:0 - [cpu time: avg 0.005 ms, total 93.601 ms] [avg calls per frame: 1]
00:20:49: Convert444Threads - [cpu time: avg 1.322 ms, total 45817.5 ms] [avg calls per frame: 2]
00:20:49: | Convert444toNV12 - [cpu time: avg 1.319 ms, total 45692.7 ms] [avg calls per frame: 2]
00:20:49: encoder thread frame - [cpu time: avg 1.004 ms, total 17394.1 ms] [avg calls per frame: 1]
00:20:49:
00:20:49: =====Stream End: 2013-10-15, 00:20:49=================================================
Last game capture log:
2013-10-15, 00:11:09: we're booting up:
00:11:09: D3D9 Present
00:11:09: (half life scientist) everything.. seems to be in order
00:11:09: D3D9EndScene called
00:11:09: D3DPRESENT_PARAMETERS {
00:11:09: BackBufferWidth: 16
00:11:09: BackBufferHeight: 16
00:11:09: BackBufferFormat: D3DFMT_X8R8G8B8
00:11:09: BackBufferCount: 1
00:11:09: MultiSampleType: D3DMULTISAMPLE_NONE
00:11:09: MultiSampleQuality: 0
00:11:09: SwapEffect: D3DSWAPEFFECT_COPY
00:11:09: hDeviceWindow: 4784666
00:11:09: Windowed: true
00:11:09: EnableAutoDepthStencil: false
00:11:09: AutoDepthStencilFormat: D3DFMT_UNKNOWN
00:11:09: Flags: None
00:11:09: FullScreen_RefreshRateInHz: 0
00:11:09: PresentationInterval: 0
00:11:09: };
00:11:09: successfully set up d3d9 hooks
00:11:09: D3D9SwapPresent called
00:11:09: DoD3D9GPUHook: success
00:11:10: D3DSURFACE_DESC {
00:11:10: Format: D3DFMT_X8R8G8B8
00:11:10: Type: D3DRTYPE_SURFACE
00:11:10: Usage: D3DUSAGE_RENDERTARGET
00:11:10: Pool: D3DPOOL_DEFAULT
00:11:10: MultiSampleType: D3DMULTISAMPLE_NONE
00:11:10: MultiSampleQuality: 0
00:11:10: Width: 1280
00:11:10: Height: 800
00:11:10: };
00:11:10: successfully capturing d3d9 frames via GPU
